Calculating frequency
14,484
it would be because you forgot to convert 200mH into Henries and 10 pF into Farads
do that and try again and you should get the correct final result ( the answer is still in Hz)
Electro132
Feb 12, 2013
261
Darn it, i got 7.02481473e-8 as the answer. This is what i did:
1 / 2 * pi * sqrt (0.0002 * (10 * 10 to the power of -12)) = 7.02481473e-8
I don't get it.
14,484
you are using the wrong numbers
200mH isn't 0.0002 H its 0.2 H
10pF = 1 x 10-11 F
Electro132
Feb 12, 2013
261
Its all good. I found out that i had made a mistake with the henries. I accidentally thought mH was micro when it was really milli. :) I guess it comes with learning. Thanks for the help davenn.
Cheers
Did you use the right multipliers? 1/1000 for mH and 1/1,000,000,000,000 for pF?
I get the answer in the example.
