Calculating Input Noise Voltage
MRW
I was just checking out various opamp datasheets. I encountered this
opamp:
http://focus.ti.com/lit/ds/symlink/tlv2784.pdf
In the few lines of text, it says that the input noise voltage is 9 nV/
sqrt(Hz) at 10kHz. But in the table at the bottom of the page, it says
that the input noise voltage is 18 nV/sqrt(Hz) at 1kHz.
How did they calculate this?
I'm curious because if I were to use an opamp (not necessarily this
one) then I would like to know how much input noise voltage it
contributes for a certain bandwidth, for instance audio band from 20Hz
to 20kHz. There was another discussion that I saw (don't remember the
link) that mentioned that at one particular design, the amplifier was
designed with a 40dB gain and the input noise got amplified to about
100mV.
Phil Allison
"MRW" <[email protected]>
** Groper fool alert.
opamp:
** See figure 19 ??
See how the EIN goes up dramatically at frequencies below 3 kHz ?
Go check some other op-amps - discover they are not all like that.
to 20kHz.
** Normally just multiply the typical or 1 kHz EIN figure by 141 (= sq
rt 20,000)
........ Phil
MRW
** See figure 19 ??
rt 20,000)
....... Phil
Thanks, Phil! I'll take a look at other datasheets. Got any opamps you
can recommend for audio?
