Resistance wire - calculating input
suryah
I'm making a hot wire cutter for polystyrene foam. Thw cutting wire will be
Nichrome.
Does anyonw know of a formula that will give me the means to calculate
possible voltage and amperage combinations to put through it (so I don't
melt the wire)?
I know that a 9v 1A setup will work, but I would like to know what others
could be used.
Rich Grise
Nichrome.
melt the wire)?
could be used.
For styrofoam, just get a decent bread knife. An X-acto, or even a razor
blade, is good for small pieces.
Don't try to cut styrofoam with a hot wire. If it gets anywhere near
hot enough to "cut" the foam, it melts it and you get a globby mess.
Or, dip the wire in glue and drag it through sand, and make a little saw
out of it.
Good Luck!
Rich
suryah
Thanks for the link. It's not dangerous. I know that the stated setup works.
It's just that other PSU's are more easily obtainable, and I wondered which
would work and which would not.
Hot wire cutters are often used in trade and by hobbyists - particularly
model railroaders. Woodland Scenics sells them - but I'm not going to pay
their prices!
