Calculating resolution.
Mymla
May 4, 2015
37
Hey everyone,
could anyone point me in the right direction to working out this question. I have the answer but not sure how to work it out of the question.
Calculate the resolution the following convert given that Vref=5V.
8 Bit
Answer: 19mV
Is this a correct formula to use? (Vin/Vref) * 2^bitdepth
Arouse1973
Adam
Dec 18, 2013
5,178
Hello. How I do it is this 5/((2^8)-1) and that gets me pretty much the same answer as you. :)
Adam
dorke
Jun 20, 2015
2,342
Adam,
You shouldn't subtract 1.
To convince yourself check the case of 1 bit ;)
Adam,
Oddly enough that was the same argument I used to convince myself that you must subtract 1.
dorke
Jun 20, 2015
2,342
I can understand why.
For 1 bit we have 2 states "0" and "1".
How do we decide which state are we in?
"0" if we are below 1/2
"1" if we are above 1/2
What is the resolution than?
I would say 1/2 not 1...;)
Arouse1973
Adam
Dec 18, 2013
5,178
Um I used to do it the other way and then I read on some website a time a go you should subtract 1. I am not saying your wrong...let me see if I can find the website.
Cheers
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
Not the website I saw but he mentions -1. But I think where I might be wrong is the maximum value FSD is Vref -1bit of resolution? Is that correct?
Adam
dorke
Jun 20, 2015
2,342
Adam,
Actually you are correct my bad.
The definition of resolution is "the value that 1LSB equals to".
In the case of 1bit it is indeed 1.
so ,subtraction of 1 is the correct way to calculate the resolution.
Another value is the "error" of a converter this is 1/2 LSB
no -1 here.
