Camera Power
camerart
Aug 18, 2010
140
I am trying to make a power supply for my Canon A460 Camera, running from a 12V Battery.
Output 3.2V- 2A
Has anyone got a circuit please?
camerart
Aug 18, 2010
140
I used a dc to dc fixed voltage chip. I now have 12v in and 3.2v out, but I'm not sure if the Camera plug is alway +v in the centre and -v on the outer ring. does anyone know please?
google for 3.3v regulator schematic.
For efficiency you'd probably want a switchmode regulator, but it's not overly simple to design one.
This video blog entry will give you an idea of what you would need to consider.
camerart
Aug 18, 2010
140
Hi steve,
I used this: http://www.national.com/ds/LM/LM2576.pdf 3.2 volt fixed output.
It needs only 4 components, I had to wind an inductor, and I only had a 1v Shottkey diode, but if I switch off the Screen before switching it on, it should be ok.
I haven't connected it to the Camera to test it yet, as i need to know how to wire the Camera plug, is it +v centre or outer tube?
Cheers, Camerart
centre positive is common, but I'd advise you to check.
camerart
Aug 18, 2010
140
Hi Steve,
Centre is +v, and the regulator works fine, thanks.
C.
