How about a 12V motorcycle battery and solar charger....check here for
something....
A motorcycle battery, like any other SLA battery, is quickly destroyed by deep
cycling. Besides a motorcycle battery is wet and that's not a good solution.
An AGM or GELL type battery is appropriate. If convenience is important, one
can buy 4 and 7ah gell batteries at Home Depot in the lighting department as
replacements for their emergency lighting products. Ditto Lowe's. Not the
cheapest source but very convenient.
To the OP (a name would be nice), Now that I see your usage plans, my first
suggestion would be to turn off the damned cellphones and teach the kids how
to relax and enjoy the outdoors.
If you really must, a battery/inverter/power strip/cellphone chargers
arrangement would work. Or a batter/12 volt multi-outlet/car adapter
chargers.
I'd just compute the total power you'll be using and carry a battery that
size. A 100 amp-hour AGM trolling battery (about $120 from Outdoor World)
should do the job. If there is no shade and you know the weather won't be
cloudy then a solar panel could be useful. Figure another $150 or so for one
large enough to matter (5+ amps).
I have a nominal 120 watt (12 volt, 10 amp) panel on my MH but with the rare
exception when I travel to Florida or south GA, it's mostly decoration. Even
in the heat of the summer up at this latitude (and heat decreases the panel's
output), I rarely see more than 3-5 amp. It is not optimally aimed (flat on
the roof) and, while still in the South, I am fairly far from the equator.
If I were camping in that situation, I'd pack along a medium sized battery
(maybe 30-40 amp-hours), a suitable battery charger and that nifty little 1000
watt ChiCom special generator that I write about on my blog. Northern sells
it during the Christmas season for $99.95. It can be found on the net in the
$100-110 range any time.
With a suitable charger, a couple of hours every couple of days would be
enough generator operation to get the job done. That'll leave you plenty of
time to play with steam toys.
Here's an idea for play. Get one of those model steam engines that are widely
available. The kind with the little electric or alcohol or solidox burning
boiler and articulating cylinder engine. Some even come with a little
generator mounted. Good for 10 or 20 watts.
to do your campfire thing, take an old disposable propane cylinder, remove the
valve, drill and tap the neck for a 1/4NPT thread and insert a steel tube
fitting. Attach some steel tubing (brake line works well) long enough to
reach the engine. At the fire, remove the fitting and fill the cylinder
partly full of water. Replace the fitting and toss the cylinder in the fire
or even better, onto a grate over the fire. Or even better still, hung by a
stand you fabricated that will keep the cylinder vertical and just in the
flame. Play with the engine until the water runs out. Rinse and repeat
When prepping the cylinder, remove the safety valve off to the side (a
standard car shraeder valve tool will work), poke some steel wool in the
bottom of the hole and then fill the rest with melted lead or solder. This is
your blow-out disc in case you over-pressure or overheat the cylinder.
The little generator could provide some charge to the battery or light a 12
volt CFL or whatever. That way you can separate your play from your power
supply.
John
John De Armond
See my website for my current email address
http://www.neon-john.com
http://www.johndearmond.com <-- best little blog on the net!
Tellico Plains, Occupied TN
Remember, amateurs made the Ark, professionals made the Titanic.
