OK, I tried a couple of LFSR things. (From which it appears that the
AVR is not the ideal chip to do this with,
since you can only shift registers one bit at a time, but I have
several lying aound
From the xilinx XAPP 52 appnote it appears that the taps for 16 bits
are Q16,Q15,Q13 and Q4.
I hope I've understood things correctly and that all bits get shifted
up one bit, and the new bit Q1
is Q16 xor Q15 xor Q13 xor Q4 (old positions).
I have the bits stored in two bytes called "low" and "high".
First I made a copy of high and copied Q4 to Q14, swapped nibbles,
cleared the upper nibble and used
what was left as an index to a 16 byte table of results of xor of Q16:Q13.
But then I found some clverness and noticed that a 17 bit LFSR only
taps Q17 and Q14. So since I can shift
registers through the carry flag, the carry flags became bit 17.
If your processor has a parity flag, you can do the whole XOR in one
AND instruction. I posted a quick little loop in another post.
Unfortunately, it doesn't.
You mean, warm up my soldering iron?!
Here's my attempt.
ldi low, $EB ; random seed
ldi high, $55 ; I don't think it's my birthday in hex, anyway.
loop:
sbc tmp, tmp ; subtract with carry ie, tmp = tmp - tmp - C, ie.
if C = 0 then tmp = 0, else tmp = -1 = 1111.1111
bst high, 6 ; store bit Q14 in flag T of status register
brtc t_0 ; jump to t_0 if T is 0, ie C xor 0 = C
inc tmp ; otherwise C <- not C
t_0: ; the last bit of tmp is now C xor T ie. Q17 xor Q14
ror tmp ; rotate last bit into C
rol low ; rotate C into bit 0 of low
rol high ; and bit 7 of low into bit 0 of high, and bit 7 of high into C
out PORTC, high ; output the whole byte. All those bits - what a waste ;-(
rjmp loop
which can be reduced further by fiddling even more with the carry flag
loop:
; status of C is maintained, a "copy" of C is made in tmp, and
tmp doesn't need initialising
subi tmp, 1 ; if tmp = 0, then C is set, if tmp = -1 then C is cleared
t_0: ; C is now C xor T
rjmp loop
This is 9 CLKs which at 16 MHz is nearly 1.8 MHz.
The nice things is that for 8n + 1 bits you always need only 2 taps
instead of 4.
So, for 25 bits it would simply be
rol low
rol med
rol high
after that you need to think of better names for the registers (and
adjust the bst instruction).
Anyway, thanks to all who replied.
colin
