Capacitor charging
73's de Edd
Aug 21, 2015
3,730
Ah-haaaa, now we have the further needed information . . . . this is related to a photoflash unit.
With several concepts of operation faults being seen.
Typical photo-flash power supply circuits have a special main storage electrolytic that exhibits a very-very low leakage, in order to hold its voltage level up for the longest possible time.
Also the main power supply is feeding a voltage sample down to trigger on that power supply circuit automatically, if it denotes a decline of voltage level being available, below a certain specification.
That design then makes a constant voltage available to supply your photoflash tube.
Now in looking back to the right terminal board and now knowing that an SCR is being involved instead, I am still seeing a fault, in it's being able to activate a photoflash tube.
With your photo flash tube not being shown in circuit, it's looking like you are wanting to connect the far ends of the photoflash between the charged capacitor and one end of the SCR with the other end of the SCR then going to the ground and possibly your thought of using the FULL . . . UN CURRENT LIMITED . . . twelve volts of the battery going through RED / ORANGE tact switch to then activate the gate of the SCR.
Your thinking there might be that the flash will then work.
BUT look closely at the center of that flash tube and see that there is a central wire usually with a conductive paint around it, and THAT wire needs several kilovolts of temporary voltage applied to it for the internal gas fill to then ionize and THEN the tube will be able to flash through that then conductive path with that high level of stored energy being in the main capacitor.
Your present transformer that is used in the main power supply looks eerily similar to what we call a trigger transformer that is typically used to fire the flash tube but it's voltage source is a small paper capacitor that is chargeed up to the order of 200 V and then applied across the primary of that transformer with a resultant multi kilovolt coming out of the secondary of that trigger transformer to then fire the flash tube.
Maybe "they " are thinking that they can repurpose the use of one of the trigger transformers for use as a power supply transformer, but I see the need of a more robust transformer for that main storage capacitors keep alive power supply application.
Can you provide any on line reference to this " kit" so that we may then get into their minds and examine their "thinking" ?
As per your very final comment on that diode, if this is an attention getting strobe.
It could be that is a voltage sensitive semi conductor device that conducts at a certain voltage build up of the main storage capacitor threshold and then feeds down to the resistor below it and if that junction was connected to the SCR gate, it would cause the SCR to conduct.
73's de Edd
CDRIVE
May 8, 2012
4,960
I sent you a private message 73's de Edd.
Mark, in amateur radio what you just did would be considered an echo. His name is Ed. "73's de Ed" means "Best regards (73's) from (de) Ed". So you're post should read "73's de Mark". ;) It was born when (Morse Code) ruled.
Chris
14,484
I'm afraid I'll have to disagree. It's not irrelevant if the cap leaks faster than the supply can charge it.
well if you want to go that way, then your ceramic us is totally pointless as it's capacitance value is going to be very limited for a start ... likely less than a few uF at most
and is not going to hold charge for any signif time compared to an electrolytic
consider you DONT have to be wary of "charged" ceramics lying around the workshop waiting to bite you cuz they don't hold a charge for any length of time,
that's where electros win
CDRIVE
May 8, 2012
4,960
I think we're having a Struther Martin moment.
It wasn't suggested to replace the 1000uf cap for operational use. The ceramic cap is only to test the PS using no load but a 10MΩ DVM. This way electrolytic leakage as the culprit can be eliminated.
Doesn't matter though because I think Steve nailed the problem. Which seems to be a misunderstanding by Mark regarding what the voltage or capacitance rating of a Cap means.
Chris
Mark34
Sep 23, 2016
53
Well i know what the voltage and capacitance of a Cap is but don't know about Cap electrolytic leakage, i did something else i removed the Cap entirely to see the inverter voltage it goes up to 30V and that's it.
CDRIVE
May 8, 2012
4,960
If that was a scope measurement it would be meaningful. With a DVM?..... Eh, not so much!
Chris
30V was the average. The inverter most likely produces short high voltage pulses, which might very well average to 30V.
Mark34
Sep 23, 2016
53
Capacitor electrolytic leakage- discharge of current between Cap plates when charged but with no load, that's not too hard to understand.
Capacitor electrolytic leakage- discharge of current between Cap plates without any charge, that's not too hard to understand.
What? that statement doesn't make sense. (how can you have discharge without charge???)
That's better, but remember that leakage exists even when there is a load. In fact it's a load all by itself. In many cases it can be considered to be a resistor in parallel with the capacitor.
Mark34
Sep 23, 2016
53
What capacitance/voltage should have the ceramic Cap for the test ? I could try another electrolytic Cap a 330V 160uF until i get the ceramic one.
I wouldn't bother. It's clear that the device tops out at 250V. We can tell that because you bought it and that was the rating of the capacitor.
There's all sorts of stuff you could try. larger batteries (D cells instead of AA), a higher voltage (try adding one more cell), or even a voltage doubler on the output.
All of these have their drawbacks, either by putting the circuit at risk of premature failure or reducing the speed/capacitance at the output.
duke37
Jan 9, 2011
5,364
To make a transformer with a greater turns ratio, you could add more turns on the outside of the transformer you have. The new winding should be in series with the existing secondary and connected in the correct phase. If you have an inductance meter, add turns to equal the inductance of the secondary.
The rectifier should be upgraded to suit and any voltage limiting feedback should be left in place.
The frequency will be very high and I expect that a 10nF capacitor will be big enough for testing.
What is the input resistance of the voltmeter?
Mark34
Sep 23, 2016
53
Don't know the resistance of the voltmeter how do I find out ?
CDRIVE
May 8, 2012
4,960
When in the DC Voltage mode Standard DMM's have a 10MegΩ input resistance.
Chris
Edit: I had to cut 95% of this reply because it was intended for a totally different thread!:oops: So if anyone read it and struggled to make a connection to Mark's question,....there was none.
