Capacitor rated voltage question.
nati levia
Mar 22, 2018
13
Hey guys and girls (maybe).
I need some help... I have 2 of the same capacitors but the voltage is different, I have a 10000μf 10v and a 10000μf 16v.
Both of them are charged to 10v, The question: will the 16v cap stay at 10000μf even if the rated voltage is lower?
Arouse1973
Adam
Dec 18, 2013
5,178
Yes it will. Some capacitors have what's called voltage coefficient which means their value changes with applied voltage but that is normally ceramics. That is a ceramic capacitor will have its rated capacitance at its rated voltage.
Adam
nati levia
Mar 22, 2018
13
Adam
Thanks adam you saved me from trying to see if its true or not and a lot of explosions.
AnalogKid
Jun 10, 2015
3,058
An overvoltage of putting 16 V on a cap rated for 10 V probably will not explode. It will shorten its life span. The rule of thumb for most electronic components is to run them at 50% of their ratings. So keep the 10 V cap under 5 or 6 volts, a 60 V transistor at 30 V or less, etc. The increase in long term reliability is very large.
ak
14,487
Adam
never heard of that before, you have reference for that please ?
that would pretty much wreck every RF circuit ever built as nothing would tune correctly
and I have built enough RF circuits that do tune properly when using the stated capacitance regardless of the rated voltage
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
It would certainly be inappropriate for tuned RF circuits to use multi-layer ceramic capacitors (MLCC), which have a huge voltage coefficient of capacitance, as resonating elements. I have always used ceramic capacitors for high-frequency by-pass applications, often placing them in parallel with electrolytic capacitors that provide low-frequency by-pass functions. All the RF circuits I have ever "played" with used either air-variable or slug-tuned single-layer ceramic capacitors as trimmers. If I needed larger values of fixed capacitance for tuning purposes, I used fixed capacitors with mica dielectrics.
I suppose there are paper and plastic dielectric capacitors with sufficient stability, but IIRC the available capacitance values are generally too large for most tuned RF applications... at least above one megahertz or so. I have used these capacitors for tuned audio oscillator and audio filter circuits without problems. I may have used ceramic caps for purposes other than high-frequency by-passing of power supply rails, but I think of that as their main use.
14,487
LOL ..... Im at the other end of the RF spectrum, particularly 1GHz and up your air variables and slug tuned caps are way too big
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Woah! Don't youse guys mix down all that giggle-hertz stuff to real RF wavelengths so your intermediate frequency amplifiers can play? IIRC, my size components can still play a role there. Pretty soon now, all radios will be direct conversion and software defined, so very few discrete components required. Might still need antennas though, so definitely room for amateur radio experimentation. Hmmm. I wonder how a ten meter diameter MLCC parabolic dish would radiate for EME communications... might not even need a feed-horn. Whoops! Woo-woo stuff there.:p
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
hahaha .... anything below 1GHz is DC, just ask any fellow amateur who knows me personally :)
Pretty much agree. Just look at my vanity website to find electrical engineering services advertised as DC to Light™. Anything between one gigahertz and a few terrahertz is just a stepping stone. Lately, almost all the interesting stuff is taking place at infrared wavelengths. At one time, the FCC allocated every wavelength shorter than a certain amount (I forget what it was) to amateur radio service, but this "right" has slowly eroded as the great unwashed discovered the joys of shortwave. Not sure what the law is in Australia.
dante_clericuzzio
Mar 28, 2016
33
Definitely yes
