Capacitor Replacement
E_\\_¼__½__¾__F
I've a couple of capacitors going bad on a motherboard. The rating of the ones on the board is 3300µF @ 6.3v. I cant seem to find
any matching at the local electronic stores but I have found some 3300µF @ 10.0v. Will these work the same or do i have to use the
6.3? Thanks.
H
Henry Kolesnik
They will work!
sometimes higher voltage one used a lower voltage might have a bit lower
capacity but the tolerance usually isn't that close..
physical fit is sometimes a probelm because higher voltage units are usually
bigger!
hank wd5jfr
E_\\_¼__½__¾__F
Thanx for the info, size shouldn't be an issue. I'll pick up the 10's and see what I can do. thanx again!
| They will work!
| bigger!
| hank wd5jfr
| > 6.3? Thanks.
Michael A. Terrell
| They will work!
| bigger!
| hank wd5jfr
| > 6.3? Thanks.
Make sure they are 105°C capacitors, or they won't last very long.
E_\\_¼__½__¾__F
105C, got it... thanx again....
| > | They will work!
| > | bigger!
| > | hank wd5jfr
| > | > 6.3? Thanks.
| Michael A. Terrell
| Central Florida
