Capacitor terminals
Lance0070
Jan 23, 2018
45
BEB4E67F-096C-4181-8A6B-8D86F77295DB.jpeg C6AFC547-AFA6-450F-A90C-8DFB054C1C72.jpeg Can any one tell me why there’s 4 prongs on one terminal and 2 on the other?
They are simply looping terminals for additional wiring. If you don't need them then forget about them.
Well, you could try the capacitance range, but there are many other parameters that your multimeter can't test.
Is there a reason you want to test it? Depending on that reason, your multimeter may only give inconclusive results.
Lance0070
Jan 23, 2018
45
I just want to know if it’s good or bad
Which is the capacitor range symbol?
It's the one with the capacitor symbol. It's between Ω and Hz.
Well... The capacitance range may tell you the capacitance (as long as your meter can read up to the capacitance of this capacitor).
It won't tell you if it has high leakage or high ESR.
Do you have any reason to think it's faulty?
Externet
Aug 24, 2009
944
Apply 12V or near to that, any polarity to the terminals for a couple of seconds.
Measure voltage at the terminals with your multimeter after say 10 minutes. If healthy, there will be a voltage reading. The closer to 12V, the better. If no voltage, it is bad.
Lance0070
Jan 23, 2018
45
It had like a oily film on it?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
The picture you uploaded shows what appears to be a 6 μF, 370/400 V AC, non-polarized electrolytic capacitor, These are typically used in AC split-phase motor applications. An oily substance present on the outside of the aluminum can is indicative of leakage of electrolyte from the capacitor. Best to pitch it and replace with a new one.
Avoid purchasing "new old-stock" or NOS parts from the Internet to replace this capacitor. This type of capacitor will "go bad" just sitting on a shelf, in its original package, after a few dozen years. Even with a "date code" there is no way to predict how long, or even IF, NOS electrolytic capacitors will work. Caveat emptor!
Lance0070
Jan 23, 2018
45
Sure is a lg split a/c unit, I’ll buy new from a store in town today thanks all for your help
