At 50 or 60 HZ, you would need VERY BIG Capacitors to Pass 5 Amps and they would need to be Rated at Considerably Higher than the Line Voltage. They should also be NON-POLARIZED.
I Do Not know Specifically Which ones you have?, But I Think you will find that If you supply 12 Volts to your Peltiers, they will probably draw about the 5 Amps.
Most of the ones I have, Have a Nominal Rating of 14,4 volts, Mainly because in a Vehicle where they are often used, that is what the Voltage is when the Car is Running.
I have Peltiers with as low as 3 Amp and up to 15 amp Ratings.
