Hello again,
About the cct I posted yesterday. You made a lot of questions and I am sorry I had not said an important detail.
A transformer of 13-14V a.c. is used. Then a full wave bridge rectifier is connected to the cct.
So, we have d.c. cycles (positive) at he upper part of the cct and the negative is the lower part, where the batteries negative terminal is conected.
Due to the fact that we have unfiltered d.c. supply, i.e. full wave rectification without electrolytic caps to smooth and keep it at high levels, the Thyristor will turn off every time the voltage reaches the zero level (100 times per second).
Now, Q1 will conduct unless Q2 is on. Q2 is on as soon as the voltage across the battery is high enough and could pass through the zener. (So, we have voltage regulation)
The LED lights when there is no charging, Q2 conducts.
The battery is 12V, not 24 as indicated in the diagram.
The cct works fine for many years in many commercial applications. It is a part of a battery charger in standby generators (24v operation). It keeps the battery charged and does not dry it out.
Transformer current capabilities, Q1's size and headsink define the supplied current ability of the cct.
Regards
P.
