audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
Hello all,
Looking for a car receiver or amplifier and saw 200W? Well it has 4 channels so each one delivers 50W, right? Maybe, but what kind of watts?
If you measure a car battery to be 14.15V when charging, then use it to power an amp that incorporates the very latest low-saturation FETs, then the power output is 14.15 squared divided by the 4 ohm load = 50W peak-to-peak. But REAL power (light bulbs, toasters and name-brand home amplifiers) is measured using RMS voltage, not peak-to-peak. So the RMS power per channel could be as low as 14.15V peak-to-peak divided by 2 = 7.075V peak, converted to RMS by dividing by 1.414 = 5.0V, squared, then divided by 4 = 6.25W RMS per channel.
The manufacturer does use a good method to boost the power by using 2 amps per channel connected as a bridge which effectively doubles the RMS voltage. So each channel delivers 5V X 2= 10V squared, then divided by 4 = 25W RMS or 50W peak, as the label says.
In the olden days, a store catalog said:" Our 240W stereo console actually provides 6W RMS continuous power per channel, with both channels operating, from 20 to 20,000 cycles per second, with less than 1% distortion, and into 8 ohms" But their marketing people saw: instantaneous (before the power supply sagged) peak-to-peak voltage (phoney double-double) with only 1 channel operating (so that the power supply is extra high), at only 1K cycle (since the amplifier could not provide much power at 20 or 20,000 Hz), with a horrible amount of severe distortion (but extra numbers), and into a very low resistance (lots of current, before it blew-up).
And I see for sale a tiny stereo amp, made in a country that I never heard of, that has printed on it "1000 Watts". But since it has only a 1/4A fuse, I know that 1/4A X 14.15V = 3.5W input, X 0.7 amp efficiency = 2.45W for both channels. So they are using the store's marketing numbers-crunching AND they left-out the decimal point(100.0). Maybe that's why the small print says to use only 32 ohm headphones, not speakers.
