Cells with different voltage in parallel????
Ian Wright
Nov 21, 2017
6
I can't find any reading material on this because I know you are never supposed to do it but I have a question asking for the Vout when I have the following 3 cells on their own in a parallel circuit:
V1 - 5V
V2 - 5V
V3- 4V
Even though you are never supposed to do this is there any formula that relates to calculating the Vout of such a circuit? I know that if it was in series the 5V batteries would slowly drain and the 4V battery would slowly gain but I'm lost at what happens when they are in parallel?
Laplace
Apr 4, 2010
1,252
Is this a theoretical circuit or a real physical problem? The assumptions made about theoretical cells make it difficult to determine what might happen in a parallel situation, unless you can calculate the voltage drop caused by an infinite current flowing through a zero resistance. But real physical cells all have some internal resistance greater than zero, thereby making the solution approachable. However, the behavior of a real cell under reverse current flow would depend on the particular chemistry involved, and who knows what else.
duke37
Jan 9, 2011
5,364
Do not do it, the 5V battery will charge the 4V battery and perhaps melt the connecting wire.
Where do you get a 4V or 5V battery? Is this describing batteries past their best.
Ian Wright
Nov 21, 2017
6
It is an entirely theoretical problem. The question is to try calculate the resulting Vout from such a circuit. I have worked out the internal resistance of each cell but struggling to come up with anything else simply because I have no idea what formulas to consider. I can find no reading material as all I can seem to find is on the matter is "Do Not Do This!" - but that doesn't help for my homework question as I am expecting to show workings etc and come up with some figures...
Ian Wright
Nov 21, 2017
6
duke37
Jan 9, 2011
5,364
Show us your circuit with resistances. How did you determine the internal cell resistances?
14,317
With an ideal voltage source this "entirely theoretical" problem cannot be solved. The source with the higher voltage will force an infinite current into the sources with lower voltage in its fruitless attempt to raise the voltage of the combined circuit to the higher voltage.
With real voltage sources having an internal resistance > 0 Ω this can be calculated by solving the node equations for this equivalent circuit:
Set up the node equations using Kirchhoff's laws, then solve for Vout.
14,317
Not so. Why should the 4 V source be charged when the 5 V sources are discharged? Consider the current flow in such a series conenction to come to the right conclusion.
That is true IF you are confusing series with parallel.
