Ceramic Capacitors
H2814D
Nov 4, 2017
258
Hi all. I have pictured a couple of ceramic capacitors. I know the one on the left is a "monolithic" ceramic capacitor, and the one on the right is simply a "ceramic" capacitor. They both hold the same value. My question is, are they interchangeable in a circuit? The ceramic capacitor was in the circuit to begin with. I have researched both types, and the "ceramic" one is suggested for the audio circuit it is in, but exactly what is it about them that makes them different? Can you explain that to me please? And thanks in advance for any helpful replies.
H2814D
Nov 4, 2017
258
"Age" meaning the monolithic ceramic capacitors have taken the place of the regular ceramic capacitors now? The monolithic is the "updated" version? Is that what you mean? And then, are they interchangeable, meaning can I install the monolithic capacitor in the place of the ceramic one if I want to and there should be no issues doing that? Thanks again for any helpful replies.
Delta Prime
Jul 29, 2020
2,996
I have a Bluetooth connected speaker that I take with me when I go off Roading in my sand rail it gets knocked around inside the vehicle and of course I repair it and what I’ve noticed. I replaced the ceramics capacitors because they had broken or cracked.
I had replaced the ceramic capacitors with monolithic ceramic capacitors because in my research it was revealed that it is in the manufacturing process in which the capacitors are made, makes it more physically stable .
Where monolithic capacitors are often sintered after lead welding, resulting in a more solid structure compared to standard ceramic capacitors.The choice between a monolithic and a standard ceramic capacitor may be based on factors like required reliability or environmental conditions like in my case where it gets bumped around all over the place I still use it to this day.
H2814D
Nov 4, 2017
258
Thanks Delta. I do agree that the physical make-up of the Monolithic Ceramic Capacitors do appear to be a more solid design. With that, and your reputation here, I am confident they are interchangeable. Additionally, it appears the regular ceramics are becoming much harder to source now. Thanks again.
