Change timing period to gadget ?
Externet
Aug 24, 2009
944
Hello.
My poor vision cannot reverse engineer now this $1 non-contact AC detector probe from Aliexpress.
----> https://www.aliexpress.com/item/3256804179002546.html?spm=a2g0o.productlist.0.0.b7a676aaPvFuj1&algo_pvid=333a1c52-53be-40e8-a0fc-24db71ce29a8&algo_exp_id=333a1c52-53be-40e8-a0fc-24db71ce29a8-22&pdp_ext_f={"sku_id":"12000028920452873"}&pdp_npi=2@dis!USD!!0.83!!!!!@0bb0624416545198445276778edca5!12000028920452873!sea
It beeps like at 2Hz, would like to modify to 1 beep/chime every 60 seconds. Inside there is a 74HC14, a DC buzzer, bunch of dividing? resistors and 2 AAA cells; cannot follow tiny traces to make its schematic :-( Any help will be appreciated.
It works like the video in here if you want to see it ----> https://www.amazon.com/Mr-Electrica...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
(Ignore its flashlight feature)
Martaine2005
May 12, 2015
5,317
Hiya,
Look up bigClive on YouTube, he did a few videos and reverse engineered several of these non contact pen types.
I just looked and found one but it wasn’t your type. Go through his videos and have a look. He definitely has a couple of vids.
Martin
John Canon
Jun 1, 2022
91
The beeper sounds so happy. Why do you want to make it sound sad ?
CircutScoper
Mar 29, 2022
300
Hello.
Well, you could take the "shotgun" approach and, since the beeping period is probably controlled by an RC timeconstant, increase all the capacitances by a factor of 120.
Externet
Aug 24, 2009
944
Thanks, fellows.
Found the exact item with the 74HC14 somewhere else, but still no schematic to attempt modify it properly.
Found a schematic that claims done with a 4017 instead. It does not matter which chip, I could build it with such instead, am after only the 1 chirp per minute. How to modify still do not see it.AC sensor.png
