Charging cap with three phase
Status
Not open for further replies.
Andrew Borg
Aug 10, 2014
42
Sir I need to charge a capacitor with three phase generator. Did three diode bridge but not charging. Any clue pls?
Thks
duke37
Jan 9, 2011
5,364
Draw out your circuit.
Three diodes will need a four wire drive.
Six diodes in a bridge can operate without the common wire.
Andrew Borg
Aug 10, 2014
42
Hi duke37 you're right I meant six diodes regarding the bridge. I connected the three wires coming out of the generator to the middle of those six diodes but cap not charging.
duke37
Jan 9, 2011
5,364
Disconnect the bridge,
Measure the resistance between the alternator outputs. Three readings.
Measure the output voltage between the three alternator outputs when running. Three readings.
Measure the resistance or voltage drop of each diode at both polarity. Twelve readings.
If one reading is different to the rest, disconnrct one end and measure it on its own.
Measure voltage drop across the bridge at each polarity. Two readings.
Andrew Borg
Aug 10, 2014
42
Draw out your circuit!
Thanks guys for response here is my circuit but capacitor not charging don't know why is this??!!!
bertus
3,877
Can you measure the AC voltage between the phases?
Bertus
bertus
3,877
What capacitor do you use?
You have given no information on that.
Bertus
bertus
3,877
You say you have tried several capacitors.
What where the values of them?
Is there a load accross the capacitor?
Depending on the load, the capacitor will be drained sooner or later.
Bertus
duke37
Jan 9, 2011
5,364
Unless youu have a very sophisticated meter, it will discharge the capacitor. To get a significant discharge time you will need a large electrolytic capacitor and a meter with 10M input resistance.
Andrew Borg
Aug 10, 2014
42
Bertus
No I tried with no load
I used it on other capacitor without problem.
14,487
deletion and tidy up
Thread closed
Status
