cheap car turbo timer
mrais79
Nov 15, 2005
6
actually i wanna a very cheap car turbo timer.
my idea is use a fan timer
anyone had try this before?
idea is car power source is connect to two way switch then connect fan timer.
so if normal i switch to normal and if i want use the timer then switch to timer.
8)
ante1
Jan 24, 2004
4,138
Are you going to time your turbocharger or what?  ::)  ;D
mrais79
Nov 15, 2005
6
nop....
actually, after the long distance journey. your engine must cooling down before you shutdown the engine.
yes you can let your engine idle then turn off it. but i'm too lazy to wait in my car about 5 to 10 minutes before shutdown my engine.
that why i wanna make a timer. mean i can let my car engine running idle and shutdown by it self after 10 minutes. and i not need wait in car and shutdown my car by myself.
ante1
Jan 24, 2004
4,138
Unless it’s a crappy low budget car this would work automatically, the cooling fan will run if and as long as it is necessary after you have shut down and left your car. The only thing you have to remember is let the engine run on idle a couple of seconds before shutting it down to let the turbochargers rpm come to idle. This is to prevent the turbocharger from spinning without oil pressure, but I am sure you knew that. ;D
