Cheap wireless (RF) receiver/transmitter solution?
W
Watson A.Name - \Watt Sun, the Dark Remover\
Roger Johansson said:
Why do you need radio communication for distances of 25 m ?
A network of computers and a simple program is a lot easier, and the
students already have laptops, I presume. (The pupils get free laptops
to use in the schoolwork when then begin school at 6 years age in my
country, and all classrooms have networks built in already)
The simple function you described can be realized with a simple directly
wired circuit, if the students have no laptops. Hardware cost is
something like 100 dollars.
In short, forget the radio communication, it is extremely unnecessary for
the purpose you describe. We are trying to minimize non-important radio
communication, because there is too much pollution of the radio frequency
ranges.
RFI would be minimal in this case because the master could poll all the
slave units avery ten or more seconds, and very little time would be
spent transmitting.
But I would consider another method. Since every student seems to have
a cell phone, have them call a number and enter their ID, and then press
a key, which can be 1 to 4, or 1 to a hundred for that matter. As soon
as the student completes, it hangs up. You could service a lot of
students with just a few IVR lines.
W
Gary Schafer said:
Try garage door openers. You can program multiple codes in them and
they are available with multiple functions.
But they're all on about the same freq, and would interfere with each
other if they were used all at the same time.
K
krose
P,
You might checkout this solution: Classroom Performance System (CPS).
I does exactly what you are describing. This website is the parent
site for the product, but they use resellers for most of their
distribution.
You can search for "Classroom Performance System" and find other
resellers. In my search I found some textbook publishers are reselling
this product. If you all adopt their text, they might be willing to
cut you a deal on the technology side.
This is not an endorsement for the product, only a possible solution!
Hope this helps,
Kevin
John Fields
ranges.
I disagree. Your opinion as to what's important or not is just that:
an opinion, and may or may not be accurate, depending on the
needs/wants of someone else. In this instance it may well be that a
multitude of RF transceivers operating in a packet switching network
is the way to go, considering the costs involved with retrofitting an
existing structure with a hard-wired network, maintaining that
network, and upgrading or replacing it as time goes by.
As far as pollution from RFI goes, unless you've got evidence to the
contrary, I'm sure that devices capable of pumping out
micro/milliwatts into a specific band and operating at duty cycles
of, say, a few minutes of RF out over an otherwise silent 24 hour
period aren't going to do much to raise the noise floor.
Rich Grise
Since you didn't indicate that this was based on some "game" "quick
response" type situation, I would go the route of IR. A simple handheld
device for each student, with the output configured to send a serial #
(uniquely assigned to each student) and then the response (A, B, C ... etc.)
You could easily place a couple of receivers around the room and have them
all tied into one PC. A simple display board that gives feedback to the
students that their response was received would allow them to know whether
or not their answer has been registered (I am thinking a grid of lights, one
per student that gets reset with every question, assuming that all students
are answering every question.) The PC could give immediate feedback to the
teacher to indicate whether they understood the material, or, if this is a
true testing situation, would give immediate scores. You would also know
each student has answered before moving on to the next question.
I see it as a bunch of IR remotes transmitting to 4 or 5 carefully placed
receivers, attached to a pc running a fairly simple VB program to tally the
results.
Now if you are thinking a gaming system of some sort, most of this doesn't
work (ir is too prone to interference), but since you didn't indicate that,
I think this will work. The great thing about this layout is you can always
add remotes and basically have an unlimited supply of unique serial numbers
or number of answers (10 to 16 with most standard keypads), and can cover a
larger area by simply adding ir receivers. Each student can keep their own,
and you can probably build (buy?) them for $3 to $6 each (small board, PIC,
ir led, crystal, a few discreet components) and write the software in a day
(or have someone do it for you.)
Just an opinion
And who writes the software that parses all these IDs coming in to your IR
receiver simultaneously, i.e., all on top of each other?
Rich
d.wills
Rich
Well, if I were doing the project, then I would. Or maybe the same
undergrads that you would use for your bushbutton idea. The reason I thought
that some type of visual feedback was necessary for the students was that
if some responses clobbered each other, the student would see that his/her
response wasn't accepted and would simply push the button again. A Microchip
PIC 16F877 attached to almost any IR detector and a few other components,
programmed using the free JAL language could store dozens of respones and
could send them to the PC when polled (or the PIC could initiate the
transfer when the PC is ready.)
Note that the op's only requirements were: "only
requirements are that the devices have some sort of unique signature to map
to a particular student (though simple attacks to this like giving their
device to another student are not an issue atm), as well as that the device
allow the student to choose one of four options, and work at an acceptable
range (say, 20-25 meters). I would like to translate the results real time
to some comodity pc hardware."
As far as I know from this, only one student is answering each question. If
all (up to 100) need to answer at once, just increase the number of
receivers. If they all receive send a serial stream to the pc, and the
students are likely to respond at different speeds, then the likelyhood of
frequent problems is small, but some students will have problems almost
every time. Any normal PC should be able to handle the serial stream easy
enough and if all id's come in as something like FF12345678A where 12345678
is the serial number and A is the answer with a header of FF to signal valid
data, then it would probably be close enough to s finished product that some
tweaking would be all that is necessary to complete it. OK, you're right, a
checksum of some sort is in order to validate the incoming data stream, but
I don't think that would be too hard.
Note that I never said this was the best way to solve his problem, just
another way. Since people were sending out ideas and the OP hadn't
necessarily spelled out all of his requirements, I was just bouncing around
an idea.
-Doug
Rich Grise
The problem is, they'll be coming in like this:
000000000000111111110000000000000111111110000000000011111100000000001111
000000001111100000000111110000000000011111000000111111000000000001111100
111110000000000011111110000000000000011111111110000000000000000001111111
000000000000111111111111111000000000000000000011111110000000000000000111
000000111111111111000000000000000000011111111111110000000000000000001111
S:111110111111111111111111111000000111111111111111111111111100000001111111
Where the '1's are IR remotes with the LED "on", and the '0's are the
IR remotes while the LED is off.
How does your sensor distinguish which photons are coming from which
channel during the times that _any_ transmitter is transmitting an IR
pulse?
Rich
d.wills
pulse?
Rich
Your point is well taken, but the sensor doesn't need to distinguish between
photons from different ir remotes, it just needs to determine whether or not
it has a valid response from any remote. I would place the ir sensors on the
front wall with baffles in place to block all (most) signals but those
coming from the appropriate row. This isn't too hard to do. Now the sensor
will receive an incoming signal(s). If the sensor reads a proper header (
example - "1111000010100101"), then count the next several bytes. Receive
the serial number, answer and check sum, and then check the input. If the
signal gets clobbered by another remote, the checksum bombs and the receiver
rejects that particular input(s). This is why the visual feedback is
necessary (think bingo type board with one light per student, reset each
question). A student will push their button, see that their answer wasn't
accepted, and push again.
If we limit the number of remotes per sensor (my guess is anything less then
10 would be ok), and questions are displayed to the crowd or read to the
crowd, and there are 2 to 4 possible responses, I've got to believe that the
responses will come in over a 10 to 20 second time period per question,
making the likelihood of competing entries even smaller. A quick check on
standard baud rates for ir communication via remotes seems to be in the
100-2000 bps range. Although not particularly fast, it should be fast
enough. Yes, I know I am assuming a lot here, but I am envisioning a normal
classroom setting with some students getting the answer much more quickly
then others. With these assumptions, most student responses would be
received the first time, with a few here and there that would have to
re-enter their answer per question
Again, not a perfect solution for all situations. I.E.: if only one student
is to answer at a time, perfect and cheap. If all students are taking a
test, but the answers are not based on the quickness of a response, it will
work well for most students for most answers with cost and expandability
still being protected. If this is a Jeopardy type game speed is of the
essence, then it doesn't work at all.
- Doug
Eric R Snow
pulse?
Rich
I see advertised in Nuts and Volts small transmitters and recievers.
And small transcievers. It seems to me that each device could be
polled by a computer and when all devices have answered the computer
tells the teacher. I know there are wifi setups that let many people
connect at the same time. I believe these all ask for data from
specific devices that it recognizes to avoid interference. Sorta like
the way cell phones work.
ers
