Hi friends,
I am still new to electronics and have been trying to build a cheapest solar powered LED light using recycled plastic bottles using the following components;
1. 2 LEDs, Vf 3.0~3.2
2. Battery 4V, 4Ah
3. Resistor 3 ohm (Please suggest if it is suitable)
4. Blocking diode (dunno about diode, pls suggest what would be the best)
5. Female jack (to charge the battery)
6. Switch
7. 1 Watt, max output - 8.3 V solar panel
I connect the 2 LEDs in parallel and install the resistor and switch. I don't know what type of blocking diode I should use. I bought many of 10V 5 ah diodes from electronics shop. They are very big and they block some current at first but they do not block the current at all after a few days. Then I put everything in the bottle with the switch and female jack installed on the bottle.
Please, also suggest what other component should I use for the light? This LED lamp is intended to introduce millions of poor households.
2. Battery 4V, 4Ah
6. Switch
