For Sale: Cheep Til311 DIS1417 Texas and other Seven Segment displays and LEDS
Status
Not open for further replies.
moff13
Oct 16, 2015
Hi I have lots of brand new leds and displays I need to get rid of. if anyone is interested PM me
Cheep TIl311 Alphanumeric Hexadecimal Display Logic
Part number Description
Digital Displays
HDSP-C2A1 AlGaAs Red 2.3” Single Digit PCB Based LED Display (Common Anode, Right Hand Decimal)
HDSP-C2E1 Red 2.3” Single Digit PCB Based LED Display (Common Anode, Right Hand Decimal)
HDSP-N103 AlGaAs Red 20 mm Low Current Seven Segment Displays Common Cathode Right Hand Decimal
HDSP-7801 "Green 7.6 mm(0.3 inch) Micro Bright Seven Segment Displays viewing distances up to 3 meters (10 feet)
Avago HDSP-7801 Green 7.6 mm(0.3"") Micro Bright Seven Segment "
SA10-21SRWA "Kingbright Super Bright Red 25.4mm (1.0 INCH) SINGLE DIGIT NUMERIC
HDSP-3601 Green 7.6 mm (0.3 inch) Seven Segment Displays
HLMP-2885 LED Bar Graph Array, Green, 2.2 V, 20 mA, 8, 100 mcd, 8.89mm x 19.05mm
HDSP-523E 14.2 mm (0.56 inch) General Purpose Two Digit Seven Segment Displays
HDSP-5507 HER display ± 1 overflow device feature a right hand decimal point
HLMP-2550 Light Bar Green LED Display, 50 mcd
HDSP-C1Y3 Yellow 1.0” (25mm) Single Digit PCB Based LED Display
HDSP-5553 7-Segment CC Red LED Display, 1480 ?cd RH DP 14.22mm
HDSP-B03E 18:88 and 88:88 0.56" Four Digit GaP HER Seven Segment Display
HDSP-C3G3 Green 0.36” (9.1mm) Single Digit PCB Based LED Display
Throgh hole Leds
l-59egw-ca Kingbright T-1 3/4 (5mm) BI-COLOR INDICATOR LAMP
HLMP-C223 T-1¾ (5mm) Super Ultra-Bright Red LED Lamps
HLMP-3316 T-13/4 (5 mm) High Intensity nondiffused LED Lamps narrow beam RED
HLMP-3650 5mm Standard LEDs - Through Hole Yellow Diffused 585nm 1.2mcd
HLMP-C423 AVAGO TECHNOLOGIES T-1¾ (5mm) HLMP-C423 LED, 5MM, ORANGE
Surface mount
SML-210Ytt86 SML-21 Series Yellow LED, 6.3 mcd, 2-pin 0805 SMD Package
SML-511DWT86 SML-51 Series Orange LED, 40 mcd, 2-pin 0603 SMD Package
SML-512DWT86 SML-51 Series Orange LED, 100 mcd, 2-pin 0603 SMD Package
ASMT-JW32-NVVJ1 High Brightness LED, JADE Series, Cool White, 5700 K, 105 lm, 350 mA, 700 mA
HSMG-A100-k42J2 PLCC-2, Surface Mount LED Indicator Green
ASMT-JW11-NTV01 1W Mini High Power LED Cool White 90LM
Detectors
Tsop2136ya1 Vishay IR reciever Photo Modules for PCM Remote Control Systems
PIR LHi 958 LHI958 Pyroelectric Infrared Detectors dual element TO-5 954
Status
Similar threads
Replies
2K
TIL311 Displays
Replies
3K
TIL311 Displays
Replies
Parts & Components
Replies
1K
Parts & Components
