Update time: New transformer received:
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 5, 2017 #41 Update time: New transformer received:
Audioguru Sep 24, 2016 3,656 Joined Sep 24, 2016 Messages 3,656 Nov 5, 2017 #42 I can "see" the weight of that powerful transformer.
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 5, 2017 #43 Yep, it's a little monster. Hope it doesn't tear a hole through my plastic case a la Fukushima!
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 6, 2017 #44 Update: Diode D7 double up and reversal:
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 7, 2017 #45 Update: Tricky insertion of Diode D13. Big thanks to Paulv here: Don't think I could have figured it out without his help http://www.paulvdiyblogs.net/2015/05/tuning-030v-dc-with-03a-psu-diy-kit.html
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 7, 2017 #47 Update: Installation of RV3: Have I interpreted the wiring at the pot correctly?
Audioguru Sep 24, 2016 3,656 Joined Sep 24, 2016 Messages 3,656 Nov 7, 2017 #48 Paul's schematic does not have RV3 so which schematic are you using? Your long green wire for C10 is different to what Paul did.
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 8, 2017 #49 Audioguru: I am building to your Rev 6 design as per first post on this thread.
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 8, 2017 #50 Audioguru: Correct. Paulv: C10 connects between D13 and Q3/R19 Your Rev 6: C10 connects between R19 and U3
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 9, 2017 #51 Install of RV2: Attachments RV2 2 1.jpg 23.2 KB · Views: 98
Audioguru Sep 24, 2016 3,656 Joined Sep 24, 2016 Messages 3,656 Nov 9, 2017 #52 Your wires for RV2 are much too long and will act like antennas that might make the opamp pickup hum and other interference.
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 9, 2017 #53 Oooh! Thanks for that. Easy to fix. Does that not apply to Rv3?
Audioguru Sep 24, 2016 3,656 Joined Sep 24, 2016 Messages 3,656 Nov 9, 2017 #54 I think that RV2 and RV3 should be mounted on the top or bottom if the board with very short wires or a new pcb should be used that has them included.
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 9, 2017 #55 Understood Thanks audioguru
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 14, 2017 #56 Update: Progress on heatsink with 2 x 2N3055(insulated), BD139, LM7812, bridge rectifier and thermocouple for fan. Crowded?? Nah! Bridge rectifier is 6A 50V, bit on the low side, but all that I could get now.
Audioguru Sep 24, 2016 3,656 Joined Sep 24, 2016 Messages 3,656 Nov 14, 2017 #57 I hope your heatsink has fins because usually the driver transistor and bridge rectifier have their own heatsinks. I am glad that you are using a fan.
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 15, 2017 #58 Yes, would have liked a beefier one.
Audioguru Sep 24, 2016 3,656 Joined Sep 24, 2016 Messages 3,656 Nov 15, 2017 #59 You might need a high power and noisy "leaf blower" to cool that little heatsink.
bushtech Sep 13, 2016 1,025 Joined Sep 13, 2016 Messages 1,025 Nov 15, 2017 #60 lol. I am planning on doing a boxing a la car radiator. If it doesn't work I'll have to get a bigger one. Roughly how big should it be? Thanks for your guidance. I am a babe in the woods here.
