Dear all,
I would like to use a stepper motor and the vendor gave me a driver for this motor.
The driver has an input to connect the motor on to it (this input is composed from 4 entrance : phase A, phase A', Phase B, phase B').
I know that I should use 48 V supply voltage for this driver and the phase current will be less than 10 A (to obtain high torque values which I want !).
So to connect the motor to the driver I need to choose a cable capable of supporting these voltages, and currents.
The problem is that this cable should be "Sheilded" as the data sheet tells me.
I found the following product:
http://www.distrelec.ch/en/control-cable-shielded-x2-50-mm-sold-by-meter-lapp-oelflex-cl-110-cy-blk-1kv-4g2/p/15581665?q=*&filter_Category3=Câbles+réseau+/+Câbles+de+contrôle+/+Câbles+de+données+/+Câbles+en+fibres+optiques&filter_Section=2.50+mm²&filter_Category4=Câbles+de+commande&filter_Conducteurs=4&filter_Buyable=1&page=3&origPageSize=50&simi=96.72
Do you know if this cable can support high current? and if I can use it to connect the motor to the driver?
Many thanks and bests regards
