Circuit Board Carbon Arc
Chris
I have a 55 year old door chime clock and the board has carbon arcs which is
causing a short. I have seen boards with this problem before and they were
repaired using some type of filler. What is used?
Thank you for your help
Chris
Bob Larter
which is
I'd scrub the board with alcohol & a toothbrush, then spray it with a
conformal coating. I can't think of any brandnames off the top of my
head, but I'm sure that many people here will have suggestions.
baron
Meat Plow Inscribed thus:
How do you get carbon arcs on a low voltage door chime board?
From the open contact points spark/arc. Though I would have thought
that it could be cleaned off.
PeterD
Chris
This doesn't sound right, you can't arc with 24 volts. But, if it fact
it has happened, I'd recommend using a dremel to grind out the bad
parts of the board, and spray with a insulating coating, or even
fingernail polish.
Chris
The carbon builds up then it arcs across. If you are thinking that low
voltage will not arc, you are mistaken. Take a 9volt battery and put steel
wool across both contacts. It will cause a fire. My kids use to love doing
this at the kitchen table when they were young.
Chris
Chris
fingernail polish.
You can arc with 24 volts. That is like saying a car battery will not arc.
It happens quite often.
Chris
GregS
I scrape out the black manually or with a Dremel tool.
I then coat the bad part with nail polish with a couple coats.
You could use epoxy if there needs more support.
Mesure the resistance across the arc points to
get an idea of the problem first.
greg
