H
HighFlight
- Jan 1, 1970
- 0
Hello all. I have a personal need for a small circuit. I have a good
understanding of components, how they are connected, and actually building
them, but an electrical engineer I am not. I was wondering if someone could
lend me a hand. It's probably very simple in design. Attached are my
requirements:
* Needs to be as small and light as possible.
* Attachable with Velcro. I'm imagining a PCB where the back has a stick on
Velcro pad.
* Small momentary button that when pressed, activates a 15 second timer
(approximately and no display needed). When the 15 seconds expires, a small
speaker should emit an audible chirping sound (audible from within
approximately 50-100 feet outdoors in a relatively quiet setting) at 5
second intervals. This chirping will continue until the button is pressed
again.
* There may be two buttons if size/weight/complexity is
smaller/lighter/simpler than required circuitry with single button.
* Replaceable battery (I'm imagining a watch size battery).
* Should be able to take a bit of bumping around. It is for a child's use
and will be attached to something that will undoubtedly be thrown or
dropped.
* Did I mention as light as possible???
I've bought from Allied et all in the past, so buying the speaker, buttons,
battery holder, etc. shouldn't be a problem. The physical layout and PCB
building should be something I can do. This is just a little project for my
son and me so I can just etch a board (hopefully one layer is enough). I
just have no idea what components to use.
Thanks very much for any assistance!
Jon
requirements:
Velcro pad.
again.
dropped.
Jon
