Jamie
- Jan 1, 1970
- 0
Hi all,
I am trying to design a circuit which will alter the current presented to a
solenoid.
The solenoid is a variable pressure solenoid, so the less current it gets,
the higher the regulated pressure.
The solenoid is controleed by a unit which produces a current ramp to the
solenoid, usually starting at around 900ma and tapering off to around 600ma.
I need to increase the pressure,and currently i am doing it by applying an
18 ohm resistor in parallel with the solenoid. This reduces the current by
about 120ma which is pretty much what im after.
Instead of having this resistor fixed, I would like to use a transistor or
FET of some sort to allow me to adjust the current to the solenoid, by
effectively paralleling the solenoid.
This section of the circuit will need to operate from a 1.0 - 4.5 volt input
I have attached a basic circuit of what I am after on
alt.binaries.schematics however it is just a 2 minute design
If anyone can help with a proper design, or anything at all it will be
appreciated.
Please email me jamie_s_22 AT hotmail.com
[AT = @]
Thankyou
Jamie
solenoid.
appreciated.
[AT = @]
Thankyou
Jamie
