Circuit help: switching a load only at peak of AC mains
JB
I have a series of measurements to make of the inrush current of a range of
LED drivers and electronic ballasts. Is there a simple way of ensuring that
the load is always switched on at the peak of the mains cycle? I'll probably
use a substantial relay or thyristor to do the actual switching. This is for
a single phase 230V 50Hz supply.
I have done zero crossing triggers for switching loads but never peak! My
Google mojo seems to have deserted me on this one. Any help much
appreciated.
JB
Phil Allison
"JB"
of LED drivers and electronic ballasts. Is there a simple way of ensuring
that the load is always switched on at the peak of the mains cycle? I'll
probably use a substantial relay or thyristor to do the actual switching.
This is for a single phase 230V 50Hz supply.
appreciated.
** Well, a zero crossing detector followed by a 5 m/S delay will do it.
I know someone with exactly the same task as yours and he used a PIC
programmed to get both zero and peak switching of a triac - which he also
bypassed with a hefty relay operated simultaneously to eliminate glitches
associated with some of the loads encountered.
.... Phil
petrus bitbyter
appreciated.
JB
Can it be that difficult to make a 90 degrees shifted sine and switch on the
zero crossing of it?
petrus bitbyter
George Cornelius
Timing it is easy. But if it is part of a regulation scheme the thyristor
will also have be capable of being turned off while carrying full current.
What's the term for this - commutation?
Or is this a problem of designing a solid state relay that remains on for
one or more cycles, one where it is allowed for the thyristor to turn off
on its own at the next zero crossing following the arrival of the "off"
signal?
George
Daniel Pitts
appreciated.
JB
Can you just give it the right voltage as a DC pulse to perform your
measurements? That seems like an easier task to me.
Daniel Pitts
appreciated.
JB
Phil Allison
"Daniel is the Pitts"
** So stupid, it's actually funny.
.... Phil
petrus bitbyter
signal?
George
The OP only asks for switching on so far. There are dozens of SSRs for sale
designed for switching on at zero crossing. So you use the shifted sine to
switch on the not-shifted. As for switching off GTO devices can be
considered. Common SSRs switch off at the zero crossing of the load current.
petrus bitbyter
Phil Allison
"petrus bitbyter"
sale designed for switching on at zero crossing. So you use the shifted
sine to switch on the not-shifted. As for switching off GTO devices can be
current.
** The loads being considered are essentially off line switchers (
PS ) - so the current draw falls to near zero just after each AC voltage
peak, requiring the SSR to be re-triggered every half cycle at the next
peak.
Or, just drive the LED on continually until you want the SSR it to
commutate off.
..... Phil
Daniel Pitts
Why don't you enlighten rather than belittle?
You are? Well, I'll try not to laugh at you.
If the OP needs to make a measurement of the inrush current on the LED
drivers and ballasts, why not simulate the conditions the easiest way
possible?
Phil Allison
"Daniel Pitts" = "Daniel is the Pitts"
** No-one can teach a pig to sing.
And you are another PITA fucking troll.
Piss off.
Daniel Pitts
Piss off.
Lol, I think you were looking in a mirror and saw the troll.
*plonk*
Phil Allison
** **** you - pig brain.
Jasen Betts
use a dimmer and adjust it while observing?
