johndeverill
- Nov 16, 2004
- 40
- Joined
- Nov 16, 2004
- Messages
- 40
I wonder if anyone can give any advice on a circuit I want to build.
I have a pressure transducer that output 0-100mV for 0-30psi.
I have a solenoid that is activated by 12v.
I want to control at which pressure the solenoid is activated.
The circuit I imagined would be the transducer sending a signal to a potentiometer and then to a transistor, which would let the 12v through to the solenoid. I thought that if I sourced a transistor that activated at 1mV the pot could be used to vary the pressure.
Does this make sense?
Also I want to put a stage in before the solenoid that would be an astable 555 circuit so that I could pulse the solenoid. Does anyone know of any example of 12v astable 555 circuits that I could use as a guide.
Many thanks in advance and hopefully someone can help!!
