Tim Wescott
- Jan 1, 1970
- 0
Or power-on transients, and if you include that in your simulation inCharles said:Real oscillators start up because of noise.
LTSpice then they start just fine.
Lacy said:I use Multisim 2001 and the only circuits I know it will not handle
at all are CMOS Oscillators.
I've never needed to use an 'external stimulus' to start an oscillator
in LTSpice. It always delivers the goods.
If you want a circuit that should not work, how about an emitterKevin said:You mean you actually get... EWB to like.. work at all... wow...
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
You mean the "point" of the pin...Bob said:It appears to have some kind of noise stimulus built in. Some other spice
variants (notably, Circuit Maker) seem not to do this, and end up with
circuits balanced on the head of a pin, so to speak.
What makes you think there is any correllation whatsoever withI remember someone once posted about a circuit that Spice said should
be unstable, yet when built, the circuit works perfectly fine.
What circuit was this? What other circuits don't work in simulations,
but work perfectly fine in real life???
simulations and real world performance?
John Larkin said:Simulations are valuable, provided you already understand the circuit
well enough that you don't really need to simulate it.
John
Don said:What makes you think there is any correllation whatsoever with
LTSpice, surprisingly enough, seems to do a pretty good job with
oscillators. Whatever they did to it to optimize it for switching power
supplies seems to have made it fit for this, as well.
Robert Latest said:So does LTSpice use a different or improved engine, but works
with ordinary Spice models?
All I ever use is the good old original free Spice on Unix, and I
always thought that the derivatives (like PSpice) used the
identical engine with some added GUI sugar.
Clarification welcome.
robert.
There are several classes of circuits that often do not model well in Spice,Paul said:I've never needed to use an 'external stimulus' to start an oscillator
various (often simple like Hartley or Colpitts or three logic inverters and
a crystal) oscillators is a typical example. What irritates me is that
LTSpice badly fouls up on simple "brute force" <rectifier and big capacitor
(with or without a series inductor)> power supplies. No other Spice that
i have used fouls up in this way.
[...] What irritates me is that
JosephKK said:a crystal) oscillators is a typical example. What irritates me is that
Fouls up how?
I've modeled:
(V) --- 0.1F
GND !
GND
With no problem.
I've also modeled:
K1
) ( L2 ! !
) ( ! --- C1
L1 ) +-- GND ! !
------ ( ! GND
Where (IIRC):
L1 = 100mH + 2R
L2 = 1mH + 0.1R
K1 = 0.95
C1 = 1000uF + 0.01R
... and got good results.
try a standard full bridge from 120 60 Hz into a 5000 uF cap and 240 ohmsKen said:Fouls up how?
I've modeled:
(V) --- 0.1F
GND !
GND
With no problem.
I've also modeled:
K1
) ( L2 ! !
) ( ! --- C1
L1 ) +-- GND ! !
------ ( ! GND
Where (IIRC):
L1 = 100mH + 2R
L2 = 1mH + 0.1R
K1 = 0.95
C1 = 1000uF + 0.01R
Joseph2k said:try a standard full bridge from 120 60 Hz into a 5000 uF cap and 240 ohms
load.
