hi.
i just want to know what causes a circuit not to work if it is build bigger than the size stated in the circuit diagram.i just buid a tv signal amplifier but when i used it on my tv, the signal was even worst.it was about trice the original size.
i build it on a cartboard paper as i did not have a pcb.
i tried buying one(4.5by5.3 in dimension) online but it was very expensive at about 26dollars but including shipping, but 10pieces will cost $36 but one is not $3.6.there is a money sendine company called money gram in my country cameroon.the minimum amout of money you can send is about $8.if there is someone that can make me a pcb and post it at this price,i will be very greatful as it looks like my circuit will not work without it.
i have a BFR72(or 92 )transistor.it has very short leads.i am afraid i will over heat it while building the circuit as i have only a 60W shoulder.are the transistors very resistant to heat?if not what can i do to make the connections without destroying it.
thanks
thanks
