Class D audio amplifier recommendation
Mook Johnson
I think Cladd D audio might be a neat thing to play with. I've heard that
the sound quality can suffer if the component selection is not done
correctly.
Any recommended components that have proven themselves with sound quality.
This will be a bout a 15-25 watt power supply from batteries so it needs to
be efficient.
Ross Herbert
|correctly.
|be efficient.
There are a number of IC's around for Class D amps (Maxim, National
Semi, Zetex, NJR etc) but you would have to do all the work necessary
to get it into a working design. If you wanted to start with a proven
design you might consider the ZAPpulse from LC Audio
http://www.lcaudio.dk/com/zp2.htm although this sounds a bit of an
overkill for your requirements.
analog
heard that the sound quality can suffer if the component selection
is not done correctly.
quality. This will be a bout a 15-25 watt power supply from
batteries so it needs to be efficient.
Check out http://www.diyaudio.com/ and follow this set of links:
diyAudio Forums > Top > Amplifiers > Digital Amplification, or just
go here http://www.diyaudio.com/forums/forumdisplay.php?s=&forumid=49
Do it yourself techniques and advice for building class d amplifiers
are discussed as well as most commercially available class d amps
and kits.
Ross Herbert
On Tue, 05 Oct 2004 03:22:41 GMT, Ross Herbert
|On Tue, 05 Oct 2004 02:20:18 GMT, "Mook Johnson" <[email protected]>
||correctly.
||be efficient.
You might also take a look at the IR website for Class D design info
http://www.irf.com/product-info/audio/classddesign.html
W
Winfield Hill
Ross Herbert wrote...
Ross Herbert wrote:
|| that the sound quality can suffer if the component selection is not
|| done correctly.
|| quality. This will be a bout a 15-25 watt power supply from batteries
| to get it into a working design. ...
It's surprising to see a list of class-D amplifier IC manufacturers
without the 800-pound gorilla of class-D IC technology, namely TI.
dd
Used a Maxim part DC coupled as a servo driver with complete success.
TI also have an "alternative" approach which reduces the fundimental
carrier component and increases higher frequency components to ease the
LPF design to the point where they claim that the LS inductance does the
job, any comments?
Pooh Bear
correctly.
The performance of Class D can be truly dreadful if not carefully implemented.
be efficient.
See www.tripath.com
TI also do some lowish power Class D stuff.
Graham
Joerg
Hi DD,
the LPF design to the point where they claim that the LS inductance
does the job, any comments?
If there were cables going to the speaker I would feel quite uneasy
about that.
Regards, Joerg
Ross Herbert
On 5 Oct 2004 05:55:31 -0700, Winfield Hill
|>|| done correctly.
TI = etc
