clean coating from PCB
aurgathor
I took apart a UPS, and the PCB, including a significant portion
of the components on it are coated with some kind of clear and
shiny lacquer. This is nice for some things, but now I can't read
the markings on the chips. What kind of cleaner is best to clean
the coating from the chips?
TIA,
aur
philo
TIA,
aur
i'm sure this will work
http://www.mgchemicals.com/products/8310.html
but i'm also sure it'll be toxic as hell
so be sure to use it in a well ventelated area or outdoors
W
William P.N. Smith
I'm not sure that it's supposed to come off, and any solvent that will
remove it will probably tear the {markings, epolxy bodies} right off
thise chips...
Guest
I think its called conformal coating and a real beast to try any repairs, I
inspected them and when the vendor repairs them they really look bad and
unreadble!!!
timba
aurgathor
Guess what, I figured I'll just try all my applicable household
chemicals starting with the mildest one (Isopropyl Rubbing
Alcohol), and I hit the jackpot right away!
A cotton swab dripped with rubbing alcohol plus a bit of
rubbing followed by wiping with dry toilet paper works
like a charm on this particular type of conformal coating.
(I only cleaned the top of the ICs so far)
I wonder if it's acrylic or urethane based, (based on one of
the posted link) and what does it going to do if I heat it up.
BTW, I found a bunch of comparators, some Schmitt triggers,
a PWM conroller, and a quad AND gate. Appears to be a
fairly trivial circuit.
Thanks for the links and the follow-ups.
EN
The clear coating is called conformal coating.
I guess you've found out that there are different kinds of conformal
coatings,
silicone and urathanes. I have used Zip-Strip, a paint stripper, and it
'does not'
remove any markings from the IC's. The conformal coating bubbles up.
Use running water to wash the board off.
