Help in clean circuit
Fabulous87
Oct 20, 2022
I need help in making the following circuit clean and look professional. Any US based company that can help in designing a PCB ? The resistance is 10k ohms.
It’s an open collector circuit consisting of a transistor, a resistor and bunch of wires to synchronize an X-ray source, detector and rotational stage. We are using an NI-DAQ card for synchronization.
I would appreciate any help where I can order something and plug in those wires into it. That way it looks clean and I can focus on the imaging part research.
Thank you
A newbie
I'd solder it up and shove some heatshrink over the whole deal.
Other than that there are quite a few online pcb makers that will make you ( possibly about 50 or more using panelize given the size) for less than $10 delivered.
China but if you want to be picky perhaps there are US based ones .
14,317
No need for a custom pcb here. Use perfboard, a bit of wire and solder.
Use heatshrink as suggested by @Bluejets for insulatio, if required.
