Clocks - Integrated?
bobleny
Oct 3, 2006
141
Im doing a project, and it's really sorta small, ... its a 4" cube..... I'm trying to build a binary clock for it.
current time - for me anyways
Code:
  O o O o
o O o o O o
where "O" is on and "o" is off. Does anyone have any ideas for this? It is running off of a small voltage probably 5 volts...
I know I could build a 60hrz counter useing some 555 timers (yeah me and thoes 555s...) but i'd like something much more accurate.
Do you know of a good way to do this? Maybe an integrated curcuit of some sort?
bobleny
Oct 3, 2006
141
If, you don't know about ASCII binary, don't worrie about, it's really not needed at this point. All I need is a clock...
Ughadoo
Sep 26, 2006
13
A very simple and accurate way is through a 32768 kHz crystal oscillator followed by a clock divider.dt38.jpg
dt26_dt38.pdf
  • dt26_dt38.pdf
Ughadoo
Sep 26, 2006
13
A 4060 is even better than the 4020 because you can use its internal ports to create the 32768 kHz, as in the circuit and datasheet below:
CD4020BC.pdf
  • CD4020BC.pdf
