CMOS DRAM chips and static
Eeyore
bz said:
Why do you feel the need to insult someone that is trying to help you
understand something?
I'm never going to learn anything from a halfwit like YOU.
A half amp is .5 coul/sec. This represents about 3.121 x10^18 electrons.
A penny (1950 vintage) weighs about 3.1 gm and contains about 2.9 x 10^22
atoms.
There are clearly quite a few electrons in that penny, but NOT a huge excess
of electrons, normally.
You really are FUCKING CLULESS.
Graham
Eeyore
bz said:
As I said before, current from charge on the chip is NOT a significant
factor.
It's the bloody DISCHARGE current through next to zero ohms that does the damage
you fathead.
VOLTAGE from charges on the chip ARE the hazard.
As well.
Do your own calculations and stop calling people names.
Stop talking ignorant DRIVEL and go learn something.
Ever wondered why tote bins for electronic parts are made of high resistivity
black plastic and not aluminium ?
Just about EVERYONE in this thread has corrected your insane ideas yet you still
presevere with them.
To create the anti-static effect, the black or silver bags are
***slightly***conductive
http://en.wikipedia.org/wiki/Antistatic_bag
It's important to discharge at a slow rate,
http://en.wikipedia.org/wiki/Antistatic_mat
The World's First Real ESD Safe Foam
Amazing Constant Surface Resistivity 10^6 – 10^7
http://exdron.com/e-p-foamd.htm
http://zotefoams.com/pages/EN/techinfosheets/TIS17.pdf
http://www.google.com/search?hl=en&rls=en&hs=dxx&q=static+dissipative+foam+resistivity&btnG=Search
Now go and take your IGNORANT ideas elsewhere.
Graham
bz
the damage you fathead.
As well.
resistivity black plastic and not aluminium ?
you still presevere with them.
Says NOTHING about high current being a hazard.
This is for a floor mat, used to discharge the static build up of someone
walking across a room.
It has NO bearing upon your claim that a high CURRENT can be discharged from
a chip causing damage to the chip
WITHOUT the chip having a high static voltage on it to start with.
sales hype. No documentation claiming that high CURRENT is a hazard in the
absence of a high voltage charge.
This MIGHT have some bearing on your claims in that the resistance specs for
'anti static foam' have a range of values, but it gives no other support for
your claims.
Useless google search. Show me something that supports your claim, don't send
me on a scavenger hunt.
I would rather learn than remain ignorant and spread apparently
'superstitious nonsense' as you appear to be doing.
I agree that for some things, such as shipping containers, conductive foam is
better.
But I see absolutely no reason for not wrapping a sheet of aluminum foil
around a chip to protect it [providing care is used in transferring the chip
to the foil], or wrapping foil around some non conductive foam and then
poking chips into the foam through the foil [again, taking care when picking
up the chip and bringing it into contact with the foil].
I think your idea about high current discharge is WRONG, because, as I have
tried to show you with a few calculations, there ain't enough electrons 'in
the chip' to damage the chip due to high current UNLESS the chip has a high
static charge on it already!
Since some chips can be damaged by voltages of 10 volts [ten!], the VOLTAGE
is the hazard, NOT the current.
[quote from esdfunds1print.pdf from
http://www.esda.org/esd_fundamentals.html]
Many electronic components are susceptible to ESD damage at relatively low
voltage levels. Many are susceptible at less than 100 volts and many disk
drive components have sensitivities below 10 volts.
[end quote]
There is quite a bit of interesting stuff on that web site but I see NOTHING
about 'high current discharge' damage due to shorting pins of a chip
together.
Again, I think that is pure nonsense.
If you can support it, I will gladly change my opinion.
If you call me names and curse at me, I will stop reading your posts.
I am only willing to spend my time talking with those that have enough SELF
RESPECT that they can afford to treat others with respect also.
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
Paul
Please show me where this is documented and what family of semi conductors
to which it applies.
My calculations show that the probability of
producing excessive current flow inside a CMOS chip by use of aluminum
foil,
without already having exceeded the voltage limits of the chip, is very
small.
First, there are a lot of differences between pink antistatic bags!
they vary a lot in terms of what they are meant for, some are just for
NON-ESD sensitive components, and many are meant as ESD dissipative
bags.
Read this page
http://www.polypluspackaging.co.uk/anti-static-bags-material.php
It discusses which kind of bags you should use for different
applications. Notice that the low resistance ones are used for
shielding (Faraday cage), and the pink ones (dissipative - hi R) are
used to transport semiconductors.
Quotation from www.esda.org :
Resistance or resistivity measurements help define the material's
ability to provide electrostatic shielding or charge dissipation.
Electrostatic shielding attenuates electrostatic fields on the surface
of a package in order to prevent a difference in electrical potential
from existing inside the package. Electrostatic shielding is provided
by materials that have a surface resistance equal to or less than 1.0
x 10^3 when tested according to EOS/ESD-S11.11 or a volume resistivity
of equal to or less than 1.0 x 10^3 ohm-cm when tested according to
the methods of EIA 541. In addition, shielding may be provided by
packaging materials that provide an air gap between the package and
the product. Dissipative materials provide charge dissipation
characteristics. These materials have a surface resistance greater
than 1.0 x 10^4 but less than or equal to 1.0 x 10^11 when tested
according to EOS/ESD-S11.11 or a volume resistivity greater than 1.0 x
10^5 ohm-cm but less than or equal to 1.0 x 10^12 ohm-cm when tested
according to the methods of EIA 541. ANSI/ESD 11.31 is used to
evaluate the shielding characteristics of bags.
quotation from : http://www.siliconfareast.com/esdcontrols4.htm
ESD-protective packaging materials must: 1) be dissipative; 2) exhibit
low triboelectric charging tendency; and 3) have the ability to shield
their contents from electrostatic fields. The insides of these
packaging materials have a low charging layer, while their outer
layers have a surface resistivity that's within the dissipative range.
Dissipative materials have a surface resistance greater than 10^4 but
less than or equal to 10^11 ohms when tested according to
EOS/ESD-S11.11 or a volume resistivity greater than 1.0 x 10^5 ohm-cm
but less than or equal to 1.0 x 10^12 ohm-cm when tested according to
quotation from: http://www.esdjournal.com/techpapr/ryne/esdbags.htm
Q. During the past few months I have been trying to change our old
process of transporting our circuit boards around our factory from the
use of 'CONDUCTIVE BAGS' to the use of 'DISSAPATIVE BAGS'. I have been
unsuccessful due to the fact I cannot prove that this will benefit the
reliability of our products.
How can it be proven 'Practically' or 'Theoretically' to Justify the
extra costs incurred in the use of dissipative bags?
A. You have a good question. There is a white paper talking about
discharge times that may help. The more conductive an item is, the
greater the energy density in an ESD event. By slowing the charge
transfer (ESD event) down with a more resistive material
(dissipative), you can minimize the risks associated with conductive
ESD events. With a dissipative material, instead of an ESD event, you
will have a current ‘bleeding’ or charge balance that is better
controlled.
read here:
www.staticcontrol.com/pdfs/p1%20choosing%20the%20right%20static%20bag.pdf
this paper concerns itself most with events that are external to the
bag
read here: http://www.esdjournal.com/techpapr/eosesd/static/scp.htm
where the pink bags are at fault (because the ones used do not shield
against external events)
a typical product that does BOTH jobs, dissipative and shielding:
www.xsential.com/pdfDocs/mq1360mbb2001.pdf
papers:
White Paper - ESD Phenomena and Reliability for Microelectronics, ESD
Association, Oct., 2002
There are standards that discuss this and set requirements for
conductive (the kind of containers you're talking about) and
dissipative containers.
Site: http://www.esda.org
standards:
ANSI ESD S11.31-1994: Evaluating the Performance of Electrostatic
Discharge Shielding Bags, ESD
Association, Rome, NY 13440
ESD TR 20.20: ESD Handbook, ESD Association, Rome, NY 13440
http://www.esdsystems.com/whitepapers/wp_ESD-S20.html
although not quite relevant to the argument in this thread, you should
read this guy's experiences and his discovered gotcha's about ESD
products:
http://archive.evaluationengineering.com/archive/articles/1102esd.htm
-Paul
bz
products:
VERY interesting. I am glad I started with reading this one. Will read the
other references also and I thank you for them and the time you took to put
them together.
It has been some time (over 30 years) since I worked on a production line
and anti-static precautions were not taken. We made resistors and
capacitors.
It has been almost as long since I worked with radar and very ESD sensitive
diodes.
Since then, I have been lucky, I guess. In Baton Rouge, the high humidity
helps.
I have built some SMT devices recently, using ESD sensitive devices,
working on a foil covered bench and making sure everything was at the foils
potential.
No problems but from the info in the above reference, I can see some places
I could have run into problems if I did things differently.
Again, my thanks.
bz
infinite set.
Eeyore
You're an IGNORANT ****.
Graham
Sam Goldwasser
Michael Kennedy said:
Nice rational argument there Grahm. In my opininon you essentially
discredited everything you have said by resorting to name calling.
After reading everyone's argument, from what I can tell it seems Alunimum
should be fine for most circumstances. Even Sam says it's fine.
Does anyone remember manufacturers actually packaging CMOS chips in
in carriers with aluminum foam coated styrofoam? I wish I could find
some of those. Maybe before antistatic packaging was common.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Eeyore
So you mean you can't work out why the bags don't have low resisistivity ?
Just how fucking thick are you ?
Graham
Eeyore
Michael A. Terrell said:
Don't waste your time on the demented donkey.
Piss off Terrell, you worthless loser.
No matter what
position you start with, he has to be the devil's advocate and that the
other side. He's been doing this for years on the other
sci.electronics.* newsgroups, and he changes his screen name when too
many people kill file him.
Simply untrue.
Graham
Eeyore
potential.
A foil covered bench is a very bad idea.
Graham
bz
bags.
Read this page
The best bags to use are apparently the moisture resistant ones that have
an anti static [moderate conductive layer to avoid attracting sparks], a
highly conductive layer [Faraday shielding and good anti EMP shielding],
another other anti static layer [again to avoid sparking] and are heat
sealable and moisture proof. Pink bags are almost useless as are black bags
as they do not protect the contents from high voltage impulses near the
bag.
Nothing in ANY document I have seen so far says anything about a hazard due
to shorting the leads of an IC TOGETHER.
There is mention of discharging an INDUCED charge, via a leg during some of
the testing. The charge being induced in the assembly equipment by the
motion of the chips through the storage and assembly equipment.
One of the surprising 'reminders' [I should have remembered it from
physics] is that simply separating two conductors physically can induce a
charge. In other words, picking up a chip that has been laying on a
conductor or an insulator and lifting it vertically away from that surface
can create an electrical potential between the two objects unless they both
are grounded to a common point.
Thanks again for the interesting references.
bz
infinite set.
Eeyore
I can actually remember aluminium tubes. They didn't stay around for long.
Graham
bz
I can think of reasons for not having a foil-covered bench, but rapid
discharge of static potentials isn't one of them.
Yeah. Like when working on an AC/DC 5 tube type radio chassis :)
I usually just cover a sheet of styrafoam with foil when I am putting
together something that uses cmos chips like the
http://wb6dhw.com/AD995x.html board. And no, that is NOT a picture of the
one I built, mine is not that pretty, but it works!
I've wrapped ICs in aluminum foil when necessary, and never had any
problem.
I'd agree that conductive foam is the best way to store ICs.
Agreed.
bz 73 de N5BZ k
infinite set.
Paul
On Mon, 26 May 2008 01:30:42 +0000 (UTC), bz
.....snip!........
To get an idea of these voltages, you can make a crude electrometer
by using a digital voltmeter that has 10M ohms input resistance, and a
1 volt sensitivity. Connect the "common" terminal to a ground
(earthed). Connect a plate (say 3 in X 3 in.) through 10,000 Megohms
to the 1 volt input. You now have a 1000-1 voltage divider, whose
input is 10KM. If you scuff your feet on the floor, and touch the
plate you should be able to read up to several hundred volts (taking
the 1000-1 into account) as a result. You can get better results using
a more sensitive voltage range, and using 100,000Megohms or 1 million
megohms. The more sensitive of these devices can be used to pick up
the voltage potentials on insulators. (small surfaces to be measured
will require a smaller sense plate.) You have to be careful of the
insulation resistance of any components or "insulators" with this
device. These aren't your garden variety of resistors!
I use the 1000-1 circuit to demonstrate to students the degree of
voltages picked up during ordinary motions, and how well they are
controlled by use of a grounding strap. To really show ESD, you need a
charge measuring device that is calibrated, then it becomes real clear
just how bad things can get.
There are some cases of chips being slid out of their antistatic
tubes, the sliding action charged up the chips, (we assume the whole
chip charged up). As the chips dropped onto a low resistance bench,
they discharged through the pin that first touched the bench, and
damaged the chip.
Mechanical movement can induce a charged surface. One of the worst
offenders is sticky tape.... Components are often delivered as
"ammo-paks", or parts that are held in position by tape (like the
belts of ammunition), so that they can be fed into a machine that
removes them from the belt, and inserts the part into the circuit
board or assembly. If you stick down a piece of masking tape onto some
plastic, then tear it off, both the tape and the plastic will generate
a high voltage. In a lot of cases, if it's dark, you can see sparks!
That's a pretty nasty voltage!
A lot of plastics and insulators generate significant voltage when
they are flexed or rubbed. They can induce voltages in conductive
surfaces nearby, because they set up a potential field around
themselves. Just passing by one of these charged surfaces can induce
voltages on components.
that's why the much better static bags have both "dissipative"
surfaces (on direct contact with the shipped chip) to allow gentle
discharge currents, AND one or two layers of shielding surfaces to
reduce the effect of induced voltages from nearby charged objects. For
those reasons JPL prohibits the pink bags, and uses 3M #3370 bags,
which have shielding, dissipative layers, low "outgassing", low
contamination, and a good moisture resistance.
The bags are just a small part of the overall program.... you need
to have a very disciplined and comprehensive program in order to
control ESD.
That's where the ANSI/ESD S20.20-2007 comes into play, it ties
together all the recommendations, standards, mil-specs, and practices
into a standard that isn't scattered all over the place. This standard
then refers to many other ANSI/ESD standards, each one specific to
things like packaging, measuring, charge modelling, furniture,
machinery, etc.
-Paul
Eeyore
I've wrapped ICs in aluminum foil when necessary, and never had any problem.
Then you're either lucky or you had preciously observed good handling
precautions, so foil wouldn't have given any trouble.
It absolutely is because it allows any stored charge to dissipate slowly without
damage.
Graham
Eeyore
If you worked for any compnay I was involved with, you'd be handed your 'P45'
PDQ.
Graham
P45 = leaving employment.
Eeyore
damaged the chip.
Which is why they should be deposited into an anti-static tote bin or onto an
anti-static bench mat of 10^4 - 10^11 ohm/sq resistivity. Per EIA etc standards.
Graham
bz
....snip!........
due to shorting the leads of an IC TOGETHER.
of the testing. The charge being induced in the assembly equipment by
the motion of the chips through the storage and assembly equipment.
a charge. In other words, picking up a chip that has been laying on a
surface can create an electrical potential between the two objects
unless they both are grounded to a common point.
Nice idea on the 'electroscope'. Will play with the idea.
I have a very high impedance tube type 'electrometer' from the 50's that
was surplussed in the 70's.
I remember looking at some of these effects back then.
damaged the chip.
That I believe. What I didn't believe was Eeyore's explanation that
shorting the chips leads together caused damage due to the current flow
caused by the stored charge flowing from one lead to the other.
Yes!
I have a chair that generates a charge when I stand up after sitting on it
for a while.
control ESD.
machinery, etc.
I agree with what you are saying and appreciate the hazards of motion
induced charges.
If I were working with very ESD sensitive chips on a daily basis, I would
want a good work station, properly set up.
If I just need to put memory into a computer or build a device like the one
I built recently, I will continue to use, with caution, the techniques I
have used successfully in the past.
I will be a bit more cautious when moving things around, taking more time
and steps to discharge 'induced charges'.
Thanks again.
bz
infinite set.
[email protected]
