coleman 400 watt power inverter
have a coleman 400 watt power inverter.
DON'T have a schematic or anything that resembles this circuit.
is there anyplace I can find this?
it exploded a 100mf 16v cap.
has 2 sets of 4 power MOSFETs.
2 are shorted in the same group on the same side.
ie --- A1 A2 X X
B1 B2 B3 B4
they are STP60NF06
The cap was across the fan power which apparently came from these
MOSFETs
checked what I could - diodes, etc. - other things are at least not
shorted - could be open
question is...
what are the chances that replacing those 2 devices and the cap will
solve the problem?
CJT
ie --- A1 A2 X X
B1 B2 B3 B4
they are STP60NF06
MOSFETs
question is...
solve the problem?
Wouldn't a whole new one be cheaper?
Well, the devices are $1.01 each plus $5.85 shipping, so for $10.00 I
can replace all 4 devices and fix it -- Unless someone with experience
thinks there is more problems.
What can I say, I'm and engineer and don't believe in throwing things
away.
Dave Plowman (News)
away.
At that price try it and see, but order up some spare MOSFETs in case. The
other thing to check are the high voltage driver transistor(s). And of
course for any damage to the PCB/wiring.
t.hoehler
Hmmmm, pretty good sig!
I am in the middle of repairing a UPS that was overloaded and blew out the
four output fets. It also took out a small portion of board trace. Pretty
violent. I think I will put a .01 or .05 ohm resistor in series with the
battery lead when I fire it up after making the repair. I'm not going to
spend a lot of time fooling with this one, but like you, I hate just
chucking something if I know it can be repaired.
regards,
tom
