Compact fluorescents in enclosed fixtures
My understanding is that use of compact fluorescent bulbs in enclosed
and recessed fixtures is discouraged because the bulbs can overheat.
I'm not entirely clear on whether the problem is primarily reduced
bulb life, or if there is also a safety issue due to overheating the
fixtures. I've heard the claim that CF bulbs heat up a fixture more
than an incandescent bulb of higher wattage. How that is possible is
a little mysterious to me since it seems to me that the CF bulb is
producing a much smaller percentage of a much smaller wattage as waste
heat. But maybe the CF heat is somehow better captured.
So... throwing caution to the wind, I accidentally left a CFL bulb
(Feit 23w spiral, 100w equivalent, available all over in California
for $0.25 due to PG&E credits) on overnight in an enclosed, recessed
ceiling fixture. This morning I tentatively touched the glass cover
plate... a little warm, not hot. I opened it up, felt around inside,
the reflector and casing are only warm. I grab the bulb itself by the
ballast and by the spiral itself... warmer, but not too hot to hold.
I know from experience that these fixtures (unvented metal boxes) get
VERY hot with a standard 75w incandescent bulb. Can I conclude from
these observations that the CF bulbs are fine? What sort of reduction
in life should I expect from what seems like a very modest increase in
operating temperature?
-- Dave
W
willshak
-- Dave
Early CFLs were enclosed in a translucent plastic housing. I have a
Philips SL 18/27 18W 120V 60 Hz bulb that was distributed by the local
electric company some 18 or so years ago. If you sit it on its top, it
looks like a 1 liter drink bottle with cap. The plastic housing is
corrugated and the tube can be seen inside making two trips from the
ballast end to the tip and back.
K
Kicking Bird
-- Dave
Since the bulb only cost 25 cents, reduced life really isn't a material
issue-- unless it's in a bitch of a place to change...
mm
How can that be? I think the wattage is the full measure of how much
energy is released, and in fluorescents, a slightly? greater
percentage of that leaves the immediate area as light.
There is a much higher percentage of light, but I'm not sure that is
the same as a much smaller percentage of heat.
I'm not saying the numbers are this extreme, just saying they might
be. So say that in a 100watt bulb 98 watts go into heat and 2 watts
go into light.
Then in a 25 watt CFL if 23 watts went into heat and 2 watts went into
light, that would mean that 8 percent of the energy went into light, 4
times as much. But 92 percent would go into heat, so the fraction
compared to the incandescent bulb would be 92/98, which I think is
almost 94% of the percentage of incandescent.
But of course the absolute number, 23 watts, would be even less than a
quarter of 98 watts. So, like you say, how could the fixture
overheat?
Wow, here they are 1.66 at HD. Best price I've seen.
Wouldn't these be burning hot if it were a "real" light bulb?
Testing is better than theory. You've convinced me.
People here have said that some CFL's shouldn be mounted with the base
pointing up, or they have shorter life. I don't know if this remains
true, or the details or how much shorter, or how many have this issue,
or how clearly it is listed on the packaging if they do or don't.
Don Klipstein
Thomas said:
Although there is no real way a 23W lamp is going to heat an enclosure
to the same extent than a 75W lamp (especially when more energy is
leaving as light),
I know this is true, but a 42 watt CFL can heat a fixture more than a 60
watt incandescent does. I experimented with an 8 inch glass globe, a 60
watt Sylvania "Soft White", a 42 watt Commercial Electric spiral, and a
Raytek non-contact thermometer. The 42 watt spiral heated the globe very
slightly more than the 60 watt A19, and not just at the top.
More light *and* greater fixture temperature rise with less input power
- how? The incandescent produces a lot of infrared, much of which escapes
the fixture the same way that visible light does. With a CFL, nearly all
energy that does not get converted to visible light becomes convected and
conducted heat.
In these fixtures, the bulbs are mounted horizontal, not base-up.
-- Dave
V
Victor Roberts
fixtures.
There is no safety issue. The real issue is shorter life
than you would have in free air.
The CFL ballast is composed of electronic components and all
electronic systems have higher failure rates as the
temperature increases. One rule of thumb is a 50%
reduction in life for each 10C rise in temperature.
The part of an incandescent lamp that fails, the filament,
is already operating at a very high temperature. Therefore,
increasing the temperature by 10 or 20C does not
significantly reduce its life.
As Don has said, most of the "waste heat" in an incandescent
lamps is IR radiation at wavelengths just longer than
visible light. It can escape the fixture just as the light
does.
All of the waste heat from a CFL is very long wavelength IR
that tends to get trapped in the fixture. But, as has been
stated by others, the lower power of the CFL tends to offset
this issue so any increased fixture temperature is small for
equal amounts of light. If you used equal input power for
the CFL and incandescent sources, then the fixture with the
CFL would get hotter.
But you are not a semiconductor component.
Well, one lamp I know about was designed for 15,000 hours
life in free air at 25C so it would reach 10,000 hours in a
recessed can.
Vic Roberts
http://www.RobertsResearchInc.com
To reply via e-mail:
replace xxx with vdr in the Reply to: address
or use e-mail address listed at the Web site.
This information is provided for educational purposes only.
It may not be used in any publication or posted on any Web
site without written permission.
Don Klipstein
does.
I would like to add that for equal light output, a CFL typically has so
much less power input that a CFL heats the fixture less than an
incandescent does despite CFL being more efficient at fixture heating than
incandescent.
I have posted one data point saying that CFLs are about 50% more
efficient at heating a fixture than incandescents are. (This will vary,
because different incandescents have different percentage loss by heat
conduction/convection by the fill gas or lack thereof. The loss is
highest in the lowest current models that use a fill gas.) CFLs are
generally 3-4 times as efficacious at producing visible light as
incandescents are. So a CFL should be able to produce somewhere around
or over twice as much light as an incandescent that causes equal fixture
heating.
On the other hand, half as much fixture heating may still be too much
for CFLs since CFLs have a more restrictive upper limit on operating
temperature than incandescents have. CFL life may be shortened. Also,
excessively high temperature can cause the light output of a CFL to
decrease, color to shift, and color rendering index to decrease due to
above-optimum concentration of mercury vapor.
recessed can.
Based on how much of a heat hellhole recessed cans often are, I suspect
the electronic ballast in that lamp would have to have a life expectancy
of a goodly 50,000-100,000 hours, probably closer to or maybe even above
100,000 hours, in free air in order to have that low an impact on life
expectancy of a CFL in a recessed can. In a recessed can, air warmed by
the lamp rises and the ballast will get hotter than anything else. And
hot air around the ballast may be at least somewhat trapped there, and the
ballast often gets pretty toasty warm to put it mildly. That is true even
if the tip end of the tubing is not all that hot.
Andrew Gabriel
I suspect the problem is the small electrolytic capacitors. They dry out
and fail faster when run warm. Same thing that typically goes in a
computer monitor or PC power supply.
IME, the electronic failures in CFLs are due to the
switching transistor burning out (often explosively).
I have had the electrolytic storage capacitor fail when the
control gear has been reused for much longer than its design
life, but that doesn't stop the lamp working -- in the ones
I've had, it just goes dimmer and takes longer starting.
V
Victor Roberts
incandescent.
Don, I agree. I was thinking last night that my post on
this subject was incorrect on this point. In spite of the
higher fraction of non-radiated power, a CFL will create
lower in-fixture temperatures than an incandescent lamp of
the same light output.
The issue that got those of us working on CFLs interested in
this subject was not an equal light comparison, but an equal
power comparison. At one point in time, we naively thought
we could predict the in-fixture ambient temperature of a CFL
by installing an incandescent lamp of the same POWER in the
fixture and measuring the ambient temperature. We then
realized the now obvious fact that due to the high fraction
of "short wavelength" IR radiation from an incandescent
lamp, a CFL would produce higher in-fixture ambient
temperatures than an incandescent lamp of the SAME POWER.
heating.
I am guilty once again. I should have pointed out that
screw-base CFL lifetime is function of both the life of the
"wire lamp" and the ballast, with most failures in free air
being caused by failure of the "wire lamp." The "wire
lamp" failure rate is not a significant function of ambient
temperature.
The term "wire lamp" is GE-jargon for the fully functional
lamp portion of the CFL excluding the ballast, ballast
housing and base. Perhaps others use the same jargon. I
would love to have a better name for this part of a CFL, but
the term "lamp" is already taken since it refers to the
whole, fully-functional CFL and the term "bulb" is already
used to refer to the formed glassware before processing into
a functional lamp.
Vic Roberts
It may be that the recessed fixtures we've got are not as bad as most.
In these cans (cubes, more or less), the bulb is mounted horizontally
roughly in the middle, and there's a curved metallic reflector at the
top. So the ballast is definitely not at the highest, hottest point
in the fixture. Again, after running all night, the ballast was warm,
but I could hold it comfortably.
The box these bulbs came in says their "optimal" operating range goes
up to +140F. I think the ballast was less than 140F, maybe closer to
120F, though I haven't checked with a thermometer. I think 140F would
be too hot to touch, never mind hold comfortably?
I would be happy with a 50% reduction in operating life, given the
usual life expectancy of a CFL. Given the bulbs are $0.25 each, cost
isn't even an issue, I mainly want to avoid the environmental impact
of going through lots of bulbs.
-- Dave
Dave Martindale
conducted heat.
That's a very interesting result. However, it's worth pointing out that
the 42 W CFL was probably putting out about 3 times as much light as the
60 W incandescent. Most people replace an incandescent with a CFL of
similar light output, probably 13 or 15 W to replace a 60 W. In that
case, the fixture would be much cooler with the 15 W CFL than the 60 W
incandescent.
Don Klipstein
Victor Roberts wrote said:
I should have pointed out that screw-base CFL lifetime is function
of both the life of the "wire lamp" and the ballast, with most
failures in free air being caused by failure of the "wire lamp."
The "wire lamp" failure rate is not a significant function of ambient
temperature.
The term "wire lamp" is GE-jargon for the fully functional lamp
portion of the CFL excluding the ballast, ballast housing and base.
Perhaps others use the same jargon. I would love to have a better
name for this part of a CFL, but the term "lamp" is already taken
since it refers to the whole, fully-functional CFL and the term "bulb"
is already used to refer to the formed glassware before processing
into a functional lamp.
I was not aware of "wire lamp" being GE-specific jargon. I saw that
term a bit in this newsgroup, and knew that it referred to the lamp
minus its base and any integral ballast. As in being the bulb,
everything within the bulb, and wires coming out of the bulb waiting
for a base to be attached.
I just have in my mind non-regular people taking a look at this
newsgroup, with not especially high chance of knowing what a "wire
lamp" is, and should they be told that "the bulb is the glass part of
the lamp" may still think of as a "bulb" the thing that most Americans
that are engineers or other "technical types" outside the automotive
industry call a lamp.
Similar threads
K
Replies
19
2K
Kevin Bowling
K
Replies
1K
Eliot Blennerhassett
Replies
1K
soxlamp180w
