Comparator vs. Op Amp...
dtvonly
Mar 14, 2012
11
In general an op amp can be used as a comparator, even though the slew rate is slower. However, can a comparator be used as am Op amp?
Is this homework?
What is the difference between an op-amp and a comparator? Look at the output capabilities. How can you make a comparator output act more like an op-amp's?
Arouse1973
Adam
Dec 18, 2013
5,178
Things to think about for both.
1)Stability.
2)Input offset
2)CMR.
3)Output structure.
4)Driving logic gate.
5)Differential voltage range.
6)Common mode voltage range.
7)Speed / Bandwidth
Adam
Laplace
Apr 4, 2010
1,252
Some hints for your answer may be gleaned from Analog Devices AN-849 "Using Op Amps as Comparators" http://www.analog.com/static/imported-files/application_notes/AN-849.pdf but the most important consideration may be that comparators are not intended for negative feedback operation so have not been internally compensated nor provisions made for external compensation. What does that mean? Also, a comparator is meant to provide a logic signal, so it has not been designed with a linear output stage. What are the implications of that?
