Connector identification
Biggles2
Dec 28, 2025
3
Trying to source this particular PCB mount connector used for battery power, anyone familiar with it?IMG_4827.jpeg
Martaine2005
May 12, 2015
5,318
Give us more details.
What’s its use?, a laptop?, a tool?, a motor/fan driver?.
As far as I can tell, it’s a 7 pin connector. Without more details, it’s impossible to say.
Biggles2
Dec 28, 2025
3
It is the connector on an AR2 battery for a G-Tech Air Ram 2 vacuum cleaner. The battery pack itself is healthy and holds a good charge but the female receptacles of the connector are worn and cause intermittent operation. I first thought it was a bespoke connector to the manufacturer but have seen the same connector on compatible versions of battery packs.
Martaine2005
May 12, 2015
5,318
Alibaba and Aliexpress seem to have plenty in all sizes.
Do a google image search for “7 pin pcb mount battery connector “.
You’ll need to measure yours and also the pin pitch etc.
Failing that, get in touch with them and send a photo of yours. They may be able to help you.
baldguyfromblackpool
Dec 18, 2025
29
Martaine2005
May 12, 2015
5,318
Or…. Take a photo with google photo search?.
I’ve had good results with it in the past.
Regarding the mirror image, maybe it is a mirrored image?. I see that a lot on eBay.
Biggles2
Dec 28, 2025
3
Following on, I ended up on a search for "mista 6 pin (5+1) blade pcb mount battery connector" and got one that was 100% perfect, if it wasn't back-to-front :-(
The mirror image part must be out there somewhere, it's a case of finding the magic incantation for Google!
https://www.te.com/en/product-1123688-3.html - ? - that one's 2.5mm between pins
Same one at Mouser
https://www.mouser.co.uk/ProductDetail/TE-Connectivity-AMP/1123688-3?qs=Nd5ninFRCXjk9X8BVE1QzQ==
Well done ‘baldguyfromblackpool’, you got it spot on thank you so much. 👍
Dec 18, 2025
29
I just followed on from the previous post & it seemed to work out!
Don't forget to check the pitch etc, and the soldering configuration before ordering. Some differences you might be able to work around if you're good with a dremel etc
Another possible option might be, replace not only the connector on the board, but also the connector on the battery so they match. Whilst googling I did find someone selling the male connector off the battery, separately - a small individual pcb with flying leads - which leads me to believe it would be possible to swap out the battery prongs for a slightly different style?
