Help with pin connector identification
Status
Not open for further replies.
Streeter8
Jun 11, 2022
5
Hello - I have been trying to track down this connector someone gave me years ago. The diameter of the 4 prongs together is approx. 0.085". There are a few threads that the plastic cover uses to tighten up.
Streeter8
Jun 11, 2022
5
Do y’all happen to know the name of the specific style? I’ve ordered the mini 2mm bananas but they do not fit well for the application I use them for.
Martaine2005
May 12, 2015
5,318
Has your device got ‘female’ banana sockets?
Too loose? You can open them up a little by spreading the blades out. Quite common for older jacks.
Banana plug and banana socket.
Martin
Streeter8
Jun 11, 2022
5
I use them for testing with proximitors. They have test ports (circled in thumbnail) so the permanent wiring doesn’t need to be removed. The leaves on the mini plugs tend to break off when removing them and the body is much wider than the tip so they knock together and cause my connect to drop out. D4A97F75-39C7-4EDF-82C0-C325C35337A7.jpeg
Martaine2005
May 12, 2015
5,318
Ah ok. That unit doesn’t look like it has banana sockets.
Did your original wire and plug come with it from new?.
I would think somebody on here can tell you what connectors/jacks your unit requires.
Martin
Streeter8
Jun 11, 2022
5
No, they don’t officially make any testers for them. I’ve ordered some different parts to see if I can get something else to work.
Kiwi
Jan 28, 2013
507
Bootlace ferrules?
https://nz.rs-online.com/web/p/bootlace-ferrules/0458695
Martaine2005
May 12, 2015
5,318
Do they lock in and pressing the plastic lever above, unlock them?
The ferrules that @Kiwi mentioned might well work better than banana plugs.
Martin
Streeter8
Jun 11, 2022
5
Martin - the levers are for releasing the permanent wires. The test ports have a tension piece near the bottom that holds the pin in place but nothing locks it in.
I’m going to order a few of the piece Kiwi shared. That looks promising!
Martaine2005
May 12, 2015
5,318
Good idea, they’re not expensive.
You could always add your own connector type if you don’t mind opening the unit and changing them? Or hardwire to inside and have external connections?. Just another idea.
Martin
baldguyfromblackpool
Dec 18, 2025
29
14,487
I use them for testing with proximitors. They have test ports (circled in thumbnail) so the permanent wiring doesn’t need to be removed. The leaves on the mini plugs tend to break off when removing them and the body is much wider than the tip so they knock together and cause my connect to drop out. View attachment 55392
yeah, not designed for banana plugs
Kiwi
Jan 28, 2013
507
This thread is over three years old and OP hasn't been seen since.
Status
