I am having trouble getting my circuit to work, any help would be appreciated
Here is my setup :
I want to control 3 PC fans via a PIC using Pulse Width Modulation (PWM).
I will use one of my micro-controller outputs to open/close a transistor used as a switch. All three fans should be controlled together. With all three fans running full blast, they consume about 900mA altogether.
The problem is that the transistor i wanted to use (NPN 2n2222) only has a collector current rating of 600mA.
I have TIP31 (NPN) and TIP32 (PNP) transitors available also but the micro-controller has a maximum output of 20mA, which is not enough to saturate them.
Any ideas ?
I was thinking of wiring 2 transistors together as a "Darlington pair", could that work ?
PS: I would like to avoid using one transistor for each fan for ease of wiring.
Here is my setup :
Any ideas ?
