Hi Maksar,
Why?
They are completely different animals:
1) The BZX79C5V6 is rated at 5.6V, while the 1N4735A is rated at 6.2V.
2) The BZX79C5V6 is rated and tested at 5mA, while the 1N4735A is rated and tested at 41mA.
3) The BZX79C5V6 has a low differential resistance at low currents for good voltage regulation, while the 1N4735A has a high differential resistance for lousy voltage regulation.
The 1N4735A appears to be a pretty good voltage regulator at 41mA, so why can't we change the circuit so it operates at 41mA?
1) It is driven by an opamp. Opamps can't output anywhere near a current so high.
2) At 41mA, it dissipates about 1/4W. Therefore it will heatup a lot causing its voltage to change. D8 is the project's main voltage reference. You don't want a voltage reference in the project that changes its voltage.
In my comparison chart, I included the BZX79V6V2 so you can make a direct comparison of 6.2V zener diodes. Since the BZX79V5V6 has a lower zener voltage, its differential resistance is higher. ;D
