audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi Kain,
Your PCB looks very nice but I am sorry I didn't check it for you.
I think you missed my discussion of R4. Its 4.7K value allows a current of only 1.2mA in the project's main voltage reference zener diode, D8.
If you use a 1W zener diode for D8 like a 1N4734A (its part number or power rating isn't specified in the original project), its regulation and voltage is spec'd by its manufacturer with a current of 45mA!
At 1.2mA it barely regulates and its voltage will be much less than 5.6V. :
A BZX79C5V6 zener diode is much better, being rated with a current of 5mA. To use it properly, the value of R4 should be 1K for a zener current of 5.6mA. The other 5.6V zener diode D7 can be the same since it operates at a fairly low current. ;D
Recently another member of our forum pointed to an error I made with the connection of the emitter of Q1. It should be connected to the negative terminal of C1 like in the original project, not to the project's output negative terminal. :-[ :
