CONVERT from 15-0-15v to 9v
polyal
Sep 8, 2011
24
i have a mains powered 1khz test tone oscillator i need to
make portable
i need to convert it from 15-0-15 split rail to 9v ( battery )
this circuit generated 10v p/p
what modifications do i need to do to get about a 2v p/p sine wave
Alec_t
Jul 7, 2015
3,820
This should do what you want :-
Note the new split supply with a virtual ground (4.5V), the addition of a 10k pot to give you an adjustable output amplitude, and that the non-inverting inputs of the op-amps connect to the virtual ground. The other component values are unchanged.
polyal
Sep 8, 2011
24
thanks . . i will try that
regards
reg
ps is the pot grounded at the battery negative or should it be at
the virtual earth ? ie is the signal relative to the batt negative
Alec_t
Jul 7, 2015
3,820
The pot can be grounded at either, since the output is capacitor-coupled. What will the pot output be feeding?
polyal
Sep 8, 2011
24
it works spot on:)with either ground or -ve
i'm getting a 1v p/p sine wave ♪♪ ( at the op amp o/p )
is there anyway i can squeeze another 1volt gain out of it
it will be used for signal tracing through audio gear typically
at line level ( mixers etc )
the circuit is from a vintage soundcraft delta mixer
thanks
reg
Alec_t
Jul 7, 2015
3,820
Which op-amp? (Either should give at least 5V peak-to-peak output if all component values are as shown in the circuit I posted.)
Do you have both non-inverting inputs (pins 3 and 5) connected to the virtual earth?
Are you sure the battery is putting out 9V under load (~9mA or more)?
What load do you have on the pot wiper?
What is the virtual earth voltage relative to battery negative?
polyal
Sep 8, 2011
24
thanks for the reply
it turned out to be a build fault due to using recycled
strip board with cut track ( R10 was not connected to virtual earth )
it has now been rectified and giving a healthy 4v p/p sine wave
thanks for your help . . well chuffed
♪reg♪
