Convert 220Vac to 300Vdc 50amp
Status
Not open for further replies.
ILIAN
Mar 24, 2023
9
Good day all ,i hope someone will help me with a project .
I am trying to convert 220/240Vac to +/- 300Vdc +/- 50amp
anyone have any advice what to use ?
Thank you an advance
kellys_eye
Jun 25, 2010
6,512
300VDC @ 50A equates to 15kW of power.
Do you even have a domestic supply that can deliver that level of power? Most households (in the UK anyway) have 80A or 100A fused supplies that limits the TOTAL consumption to 18-24kW max.
You'd have to have a fixed connection to your incoming panel to power it......
14,487
hi
before I possibly close the thread, and before anyone else responds, you had better explain a few things
1) do you have the knowledge and comprehension of the power level you want to deal with ?
2) what are you trying to achieve ? that is, what do you want the 300V 50A for ? what is it going to power ?
3) where is the power being taken from ? are you at an industrial/commercial site ( usually lots of current capability mains supplies or at home, where you would not be able to do what you want to ? .... See @kellys_eye 's comments
ILIAN
Mar 24, 2023
9
hi
Hi Daven,
Please see my responses below:
1) yes i do, but not advance level
2) it is an experiment i am busy trying , which will require AC to DC it can be 220/240vdc not necessary 300Vdc as long it can handle about +/-50amp if less is not a problem
3) the power will be coming from generator 220Vac 1KV and is for home use if it works i will use 5kv
Thank you
14,317
Assuming 5 kVa, thats max. 22 A @ 220 V or 16.7 A @ 300 V.
Far from 50 A.
ILIAN
Mar 24, 2023
9
So what?
220 V
1 kV or
5 kV?
Hi Harald
the power will come from 1 kv generator 220Vac if my experiment works i will switch to 5kv generator 220Vac,
so i need help what to use to convert the 240Vac to let say 240Vdc because the power from the generator is 220 to 240 Vac
14,317
It is either 5 kV or 220 V. You can't have both. What is it?
Seems your level of understanding doesn't include correct units. Makes me wonder whether we should support your dealing with such dangerous power levels.
ILIAN
Mar 24, 2023
9
the generator is is 220Vac 5500 wats. But 1st i want to try with 220Vac 1000wats
ILIAN
Mar 24, 2023
9
Does an ordinary half bridge rectifier work?
not sure ,that is why i need help what i can use
i google it ,rectifier maybe can work but not sure which one to use
ILIAN
Mar 24, 2023
9
i am have basic not advance knowledge, but capable to do my project just need help of what to use for the conversion to dc,i really apricated your help
kellys_eye
Jun 25, 2010
6,512
Without even knowing what you intend to do with such current/voltage levels I can be quite certain that it is both dangerous (potentially fatal) and IDIOTIC give your admitted level of knowledge of the issue.
ILIAN
Mar 24, 2023
9
Hi Kellys,
i tried my best to explain what i need to do ,English is not my first language ,however IDIOTIC is bit strong word ,i am 47 years old i do have knowledge on ac/dc power not on a professional level ,the help i am looking for is simple ,what use to convert 220Vac to 220Vac coming from generator if i can work 22 A @ 220 V as per Harold i take it .is a green power experiment
Status
