Converting 1/v per octave to relative wavelength for hybrid VCO
Erich Pfister
Sep 14, 2015
Hey All,
I've got a design that will output a pulse every N clock cycles, where N is specified by an A/D converter. As such, the frequency of the pulse generating VCO is defined as Fclock/N. Does anyone know a relatively temperature stable way to calculate N = 2^(-x)? As a programmer, because I want my VCO to operate at 1 volt per octave, the obvious solution seems to be scaling my input - but I don't know if that assumption holds for physical hardware. I imagine this would take the form of some sort of exponentiator, but I do not know if hardware exponentiators will function with negative exponents.
Thanks in advance,
-Erich
14,317
There are electronic exponentiator circuits, however getting them to work stable over a range of input voltages and temperature is a bit tricky.
Since you alreadyy are in the digital domain (between ADC and VCO), why not insert a little controller (PIC, AVR...) in between and let the controller do the curve fitting/exponentiation as required before passing the ADC data on to the VCO?
