Converting a 48v sine wave inverter board to 96v
copperlogic
Oct 23, 2016
I am hoping someone can offer some advice on changing a sine wave board from 48v to 96v. I have a 96 volt battery bank. There are pure sine wave inverter boards readily available on ebay and aliexpress. Unfortunately though, 96v stuff is not very common. The boards on offer can be made to work with 12v, 24v, 36v and 60v. This is achieved by changing one resistor on the board and of course using an appropriate transformer. The 60v option has a maximum input dc voltage of 72 volts. As far as I can tell; the limitation here is the voltage parameters of the FETS. They are designed for max 80v. My question: Would it be possible to change the mosfets and gate resistors to carry higher voltage as well as the capacitors of course? My limited understanding is that the driver board requires a given voltage to work and does not care as long as it's driving the Mosfets. The feedback will come from the 240v side so things should work. I do not know how the protections would work though. Under voltage, over voltage, max current etc. Could anyone please offer an opinion? Below is the link to the product. Thank you.
https://www.aliexpress.com/item/Fre...id=e9155e17-b7c6-40db-bb2f-20a9b83d16af&tpp=1
Your link didn't work for me. But I think you can probably just replace the mosfets.
However there will likely be other things that need to be looked at as well. The power supply to the chip in the module may need to be checked.
