Trouble converting from battery power to DC adapter
Toolbox195
Mar 6, 2023
3
I am working to convert some battery powered lights to a DC power adapter. The light is powered by 3 aaa batteries and controlled by an on/off switch. The light is getting power from the DC adapter because it works perfectly when I toggle the on/off switch. But the light will not power on when I leave the switch in the on position and then power the lights.
The adapter has an output of 4.5 Volts and 1 Amp
Any ideas are appreciated!
Martaine2005
May 12, 2015
5,314
How have you connected the DC adapter?.
Sounds like the on/off switch is in series with battery wiring only.
What light is it?.
Edit: When you toggle the switch, the light works.
Does the light work properly on batteries?. If not, the switch is faulty.
Martin
Alec_t
Jul 7, 2015
3,820
What sort of light? Incandescent or LED? If incandescent then the surge current at power up may exceed the output capability of the adapter, resulting in it shutting down.
Toolbox195
Mar 6, 2023
3
The DC adapter uses dummy batteries and a wire to connect directly to a wall outlet.
The lights are lightsabers that I have mounted to a wall in my game room. The intent is to have them turn on/off via a smart plug rather than manually toggling the switch on the light. There are leds inside the light.
When I toggle the switch the light and sound works perfectly. Same as when I put the regular batteries back in.
Martaine2005
May 12, 2015
5,314
Don’t use the dummy batteries.
Go direct to + and - of the full 4.5V.
Martin
14,306
The DC adapter may not turn on when fully loaded (lights on). The current surge may put it into overload mode and turn the adapter off. Have you tried another Dc adapter?
Toolbox195
Mar 6, 2023
3
Thanks for all the ideas/suggestions.
Is there a beginners guide to connecting directly to the +and - ?
I’ve tried two different DC adapters but they are identical. Should I connect to one that is different?
14,306
If the adapters you tried are of the same type, then the they will behave in the same way. Try another one.
What do you mean by this question?
Martaine2005
May 12, 2015
5,314
I think that question was for me.
Connect the DC adapter direct to the BLACK and RED, observing polarity!.
Then you don’t need dummy batteries.
