Converting Switching Power Supply for Inductive Heating
Scott Kelley
Any reason I couldn't use a big switching power supply as the starting point
for a
500W (+-) inductive heater?
Anyone have any insight that would be helpful as I jump into this?
Thx
Scott
for a
Thx
Scott
I can think of a few, first they have a dc output! You could remove the
output diodes but then you have the problem that the voltage might not
suit your coil. They are designed to operate at a fixed frequency which
may not suit you coil either. Your coil works best with a push pull
drive, many smps are unidirectional.
Scott Kelley
I did say "starting point" :D
suit your coil.
I don't yet have a coil - figured that its design would be very dependent
upon what I could do with the power supply, and whether it was used in a
resonant circuit or step-down transformer.
It should be a fairly simple matter to change frequency.
Your coil works best with a push pull drive, many smps are unidirectional.
Any reason it wouldn't work? Optimum efficiency wouldn't be much of an
issue as long as it was within reason.
You say that many are unidirectional - are some push-pull? I could be
selective about what power supply I use (if I could find out which supplies
used Push-Pull drive).
SK
You need to design the coil to suit the job your trying to do, so thats
the starting point.
The smps transformer will only work near it's design frequency, at
least at anything like its rated power.
It's highly likely to destroy the smps.
Some big ones are push pull.
I could be
I had assumed you allready had the smps and were trying to find a use
for it. I have worked on industrial inductive heaters and it's not easy
to do, I would forget it if I were you or at least do some research
first.
